ᐅ Washbasin faucet - hot and cold swapped!
Created on: 6 Jul 2020 22:46
Anne1983
Anne1983
6 Jul 2020 22:46
A question for the experts
During our build, the plumber installed the concealed fittings (after prior discussion about which fixtures, etc.), and we installed the faucets and sanitary items ourselves.
However, with all wall-mounted basin faucets, cold and hot water are reversed.
He says this is a construction fault on our part.
I just checked with the supplier online, and the faucets are only available like this.
Am I missing something, or is he trying to cover something up here?!
pagoni2020
6 Jul 2020 23:36
This also happened to us. I then contacted Grohe and learned by email that there is a retrofit part available, which costs more than the shower faucet. Plumber joke: You only replace the blue-red dots—
I would recommend calling the manufacturer directly; they have more detailed information.
After that, you can tell the plumber whether he is right or if he needs to resolve the issue.
Mycraft7 Jul 2020 08:32
You might need a renovation like the Simpsons had in Australia to make sure the water flows properly.
Anne1983
7 Jul 2020 11:36
Ok, so who is basically responsible here? Is it us for installing the “wrong” fixtures, or the plumber for incorrectly laying the pipes?
Mycraft7 Jul 2020 11:43
Anne1983 schrieb:
The plumber, because he installed the pipes incorrectly?!
Did he really? What does the construction plan say about where the cold and hot water connections are supposed to be? That’s the only thing that matters.
pagoni2020
7 Jul 2020 11:52
Anne1983 schrieb:
So, who is basically at fault here? Is it us because we installed the “wrong” fittings, or the plumber because he installed the pipes incorrectly?!
Both can be right or wrong. It is exactly as @Mycraft says; this needs to be checked. In this context, there are no “wrong” fittings.
