ᐅ Walk-in shower: What is the recommended width for the entrance?
Created on: 10 Mar 2021 12:22
micric3
Hello forum,
once again, we need your collective expertise. Our shower measures 1.40 x 1 meter (4 ft 7 in x 3 ft 3 in). The entrance is planned on the 1.40 meter (4 ft 7 in) long side. Since the quote from our plumber for a glass panel/door seems too expensive, we are wondering if a walk-in shower would be enough?
We understand that some splashing may occur. However, we have sufficient slope for drainage, and a small towel in front should be enough.
How wide should the shower entrance be? 70 cm (28 in) ↔ 70 cm (28 in), or would 80 cm (31 in) – 60 cm (24 in) be better? Currently, we have an old corner shower with a 40 cm (16 in) wide entrance.
Good luck
m
Good luck
m
hampshire10 Mar 2021 17:22micric3 schrieb:
only the issue with the vapor barrier is a major drawback.There is no regulation requiring the shower enclosure to extend to the ceiling. A height of 2.2m (7 ft 3 in) is sufficient for average-height people.The shower access is about 110cm (43 inches) high, in case someone ever needs care assistance. Instead of a glass partition, there is a rod with a new 7.50m (24.6 feet) shower curtain from Daen. Bettenlager every three months. Currently, it is white with gray stars. It has also had jungle grass patterns, waves, or dots.
Nordlys schrieb:
The shower entrance is just over 110cm (43 inches) wide, for when someone needs care. Instead of a glass partition, there is a rod and every three months a new 7.5-meter (25 feet) shower curtain from the Danish warehouse store. Currently, it is white with gray stars. It has also had jungle grass patterns, waves, or dots. There are washable shower partitions. :p
