ᐅ Ventilation duct installed too low in the splash water zone
Created on: 2 Mar 2018 14:00
planlos1234P
planlos12342 Mar 2018 14:00Hello,
I hope you can help me, as I have very limited knowledge in construction!
I moved into my newly built house last autumn and have been wondering from the start about the height of the ventilation shaft for the kitchen extractor fan, which was only slightly above ground level before the driveway was paved. When the driveway was paved in autumn, if the workers hadn’t been careful, the ventilation shaft would have been buried halfway below ground level.
Since the area around the base is exposed to the most stress, including moisture, I’m worried that water might enter my house through the shaft, especially during heavy rain. According to my installer, everything is fine. However, a colleague at work who is not a professional suggested that the shaft should be installed at least 30 cm (12 inches) above ground level.
Is the shaft installed too low, or should the installer have chosen a different height? What should I do in case of water damage?
I look forward to your answers!
planlos12344 Mar 2018 18:58Hope this gives you a better idea now 🙂
planlos12345 Mar 2018 07:30The kitchen is located above the shaft, which runs within the screed. From the cooktop, it then goes approximately 80 cm (31 inches) straight up.
Bieber08155 Mar 2018 09:18In my opinion, this is poorly done (at least small animal protection should be ensured even at an exhaust outlet). The same applies to the long end of the orange PVC sewer pipe (KG pipe), which extends beyond ground level. Unfortunately, I cannot confirm this with official documents or legal references ... ;-). And who really knows the building codes and regulations abroad.
Who planned and built the house? Did you have an expert (certified inspector) by your side?
