ᐅ Using Billy Regal Felt Pads – Which Ones Are Recommended?
Created on: 21 Jul 2024 08:17
Peoneo48
Peoneo48
21 Jul 2024 08:17
Good morning everyone, I have been considering for some time whether I should use additional felt pads for my Billy shelf to protect the floor and improve stability. My specific question is: which felt pads are especially recommended for the Billy shelf from IKEA, and what should you look for when buying them? I mainly use the shelf for books and light decorations, but I want to prevent scratches on the laminate floor and improve the ease of moving the shelf. Are there particular brands or types that fit especially well and are durable? It would also be helpful to know if the pads can be easily replaced if they wear out. Thanks in advance for your expertise!
RENMA
21 Jul 2024 09:42
Regarding felt pads for the Billy shelf, the key factors to consider are material quality, adhesion, and fit. Felt pads with a self-adhesive backing made from wool felt are recommended, as they are more durable than synthetic options and provide better protection.
A good example are pads from brands like "Gorilla Pads" or "Felpax," as they have a strong adhesive layer yet can be removed without leaving residue. For the Billy shelf, round or square shapes with a diameter of about 25-35 mm (1-1.4 inches) are suitable to adequately cover the shelf legs.
Replacing them is straightforward: carefully remove the old pads and thoroughly clean the surface before applying the new ones to ensure optimal adhesion. This prevents detachment or dirt buildup.
In short: high-quality wool felt, appropriate size, and strong adhesion are the main criteria when choosing felt pads.
Joe52
21 Jul 2024 10:05
From my own experience, I can say that the felt pads I used really made a big difference, especially in preventing scratches on laminate flooring. At first, I wasn’t sure how well the adhesive would hold, but the pads have been staying on for several months now, even with frequent movement of the shelving unit.
What I found convenient was felt pads that can be easily cut to size if the standard size is too big or too small. This gave me some flexibility, since the shelf legs are slightly thinner than you might expect. However, I made sure to choose pads with good adhesive quality so they wouldn’t come loose and require constant reapplying.
RENMA schrieb:
Felt pads with self-adhesive wool felt backing, as these are more durable than synthetic options
I fully agree regarding the quality. 🙂
PeoDaniel
21 Jul 2024 11:23
To complement this, I would like to explain a few basics that are often overlooked when it comes to felt pads for furniture like the Billy shelf.
Felt pads primarily serve two functions: protecting the floor surface from scratches and improving the furniture’s glide. It is important that the pads are sturdy enough so they do not come off or tear during the first movement.
There are self-adhesive felt pads and those that need to be glued or stapled. Since the Billy shelf typically does not have pre-made attachment points, self-adhesive pads are the most practical option.
It should also be noted that dust and dirt can accumulate in the felt over time, which reduces the pads’ gliding ability. Regular cleaning or replacement after about one year makes a big difference.
If the shelf is relatively heavily loaded, it may be advisable to use felt pads with stronger adhesive backing or to additionally fix them with small nails, provided the shelf material allows for this.
Dustin
21 Jul 2024 12:47
For Billy shelves, I recommend self-adhesive wool felt pads with a thickness of 3-4 mm (0.1-0.16 inches) and a diameter of about 30 mm (1.2 inches). They protect laminate flooring well and usually last for several months. Simply apply them smoothly to a clean surface.
Joshbe
22 Jul 2024 07:14
A straightforward addition: Quality labels and customer reviews on sales platforms are often informative. Felt glides made from 100% wool felt provide better wear resistance than blended fiber products.
Surface preparation is also crucial, as glued felt glides will only hold as well as the adhesion surface is clean and free of grease. Durable acrylic-based adhesives are recommended, as they also minimize residue when removed.
Another tip is to use several small glides on each shelf leg rather than just one large one, as this distributes the load more evenly, which increases the lifespan of the glides.
This also applies to the Billy shelf unit, since the feet do not always rest flat.
