ᐅ Using Billy Regal Felt Pads – Which Ones Are Recommended?
Created on: 21 Jul 2024 08:17
Peoneo48
Good morning everyone, I have been considering for some time whether I should use additional felt pads for my Billy shelf to protect the floor and improve stability. My specific question is: which felt pads are especially recommended for the Billy shelf from IKEA, and what should you look for when buying them? I mainly use the shelf for books and light decorations, but I want to prevent scratches on the laminate floor and improve the ease of moving the shelf. Are there particular brands or types that fit especially well and are durable? It would also be helpful to know if the pads can be easily replaced if they wear out. Thanks in advance for your expertise!
TEOZAR
22 Jul 2024 08:59
I would like to add that there are practical alternatives for the Billy shelf: self-adhesive felt pads with a plastic outer rim, which improve adhesion and can protect the shelf from moisture.
This is especially useful if the shelf is placed on drafty or damp floors, for example on a balcony or in a conservatory. Additionally, this type of pad often provides better stabilization for wobbly shelves.
However, if you only want to protect the laminate flooring indoors, conventional wool felt pads are completely sufficient. It is important to regularly check that the pads on the bottom of the shelf legs remain securely in place.
tra_nina
22 Jul 2024 10:32
Joshbe schrieb:
Surface preparation is also important
This is a crucial point! Without thorough cleaning and, if necessary, light sanding of the underside of the shelf (e.g., with fine sandpaper), the felt pad will not adhere permanently. This can help prevent early detachment and therefore damaged floors.
Additionally, it is definitely worth buying from reputable manufacturers that specifically offer felt pads for furniture. Cheap products from hardware stores can quickly crumble or lose their adhesive strength.
Conclusion: Focus on quality, choosing the right size for the shelf, and proper application.
KLO-KA
22 Jul 2024 11:47
I used simple black wool felt pads from "Felties" on my Billy shelves. They are durable, have good adhesive strength, and do not leave any residue.
If needed, you can even secure them with tape in case the adhesive is weak. It works well and the price is reasonable.
Joe52
23 Jul 2024 09:15
Peoneo48 schrieb:
Are there specific brands or types that fit particularly well and are durable?
One brand I like to recommend is "Scotch Restickables." These felt pads have adhesive, are slightly thicker than others, and even allow you to peel them off and reposition them multiple times if you place them incorrectly. This is especially useful for a Billy shelving unit because it can sometimes be tricky to get the perfect placement.
TEOZAR schrieb:
practical alternatives with a plastic outer rim
I haven’t tried those yet, but it sounds interesting—especially if the shelf needs to be moved occasionally or if you have sensitive flooring. Thanks for adding that! 🙂
