ᐅ Underfloor heating with an air-to-water heat pump. House gets too warm when the sun is shining.
Created on: 4 Dec 2019 14:18
chewbacca123
I have a general question.
We moved into our new build four months ago. The living area on the ground floor has three large floor-to-ceiling windows facing south. We have underfloor heating and an air-to-water heat pump.
It provides a really comfortable temperature inside the house, but we have a problem – whenever the sun is shining in winter, even if it’s -2°C (28°F) outside, the temperature suddenly rises to 24°C (75°F) in the living room. It gets uncomfortably warm in here, and the underfloor heating can’t be turned down quickly.
Should we assume that the large floor-to-ceiling windows are responsible for the heat gain? A photo of the south-facing side of the house is attached.
What would you do – always lower all the blinds as soon as sunlight is forecast? That seems quite annoying...
We have motorized blinds controlled by Somfy. Would you consider buying a sensor that automatically lowers the blinds at a certain temperature?
Thanks in advance for your replies.
Ötzi Ötztaler2 Oct 2020 14:27
New construction using solid masonry, which was built up over a 5-month construction period starting in March until move-in. We are already heating regularly to prevent mold from developing despite the controlled ventilation system...
Nice-Nofret2 Oct 2020 14:46Of course we heat ... otherwise it would be too cold for me in the bathroom in the mornings ... and since we now have several days of continuous rain anyway ... who wants to sit around in damp cold.
Alessandro schrieb:
I have now set the heating curve as follows:
No balancing has been done yet. The return temperature is too high at 0 degrees, so the supply temperature is probably around 40°C (104°F).
Operating a heat pump at 40°C (104°F) is like throwing money out the window.
Ötzi Ötztaler2 Oct 2020 16:06
Bookstar schrieb:
Of course, we stoke the stove, but it only heats the living and dining area; there we have a constant 26°C (79°F) Haha, that was obvious :-pBut beforehand, it made all the end-of-September heaters look like weaklings
