ᐅ Tips for dismantling and reassembling Ikea Metod cabinet units?
Created on: 23 Feb 2024 10:27
Bente_loHello everyone,
I am planning to reassemble some Ikea Metod cabinet units and, at the same time, disassemble some of them to rearrange the layout. I want to avoid damage as much as possible and work efficiently.
My specific question is: What professional or proven tips are there for disassembling and reassembling these Metod cabinets? I am particularly interested in handling the fittings (e.g., Lamello or Minifix connectors), dealing with the back panels, the correct order of disassembly, as well as measures to prevent damage to the carcasses and decorative surfaces.
Any advice on whether and how the fittings can be reused multiple times, or if it is advisable to mark certain components before disassembly, would also be very helpful.
Who has experience or knows tricks to carry out this process quickly and carefully?
Thank you in advance!
Regarding your question, I recommend the following:
- Carefully remove back panels using a flat pry tool, as they are often fixed with nails and can break easily.
- Use the correct screwdriver for Minifix and Lamello connectors to properly release the Deloos locking mechanism.
- Number or mark the components with tape before disassembly to make reassembly faster and easier.
- Always keep screws in a small container to avoid losing them.
- Fittings can be reused multiple times as long as they show no visible damage or deformation.
- For assembly, a torque of about 3-4 Nm (2.2-3.0 ft-lb) is recommended to avoid overloading the material.
These points ensure safe and efficient disassembly and reassembly without significant damage.
PeoDaniel23 Feb 2024 14:10Hello,
I would like to add a basic point here: Metod cabinets are basically designed so that many components can be reused. However, the wood around the drill holes can loosen over time, especially if the cabinet is taken apart and reassembled multiple times.
Therefore, my tip is to be very cautious when loosening the fittings and, if possible, use a suitable cordless drill with a torque setting. If you unscrew the screws too tightly or with too much force, the threads can be damaged.
Regarding the order, I recommend removing the doors first, then the shelves and the back panels. The back panel is usually attached with nails only, so removing it first puts the least stress on the joints.
It’s also best to mark how the elements belong together and follow the original arrangement if you want to modify the cabinet rather than completely rebuild it.
I hope this helps!
I hope this helps!
PeoDaniel schrieb:
When loosening the fittings, proceed very carefully and, if possible, use a suitable cordless drill with adjustable torque settings.I can only emphasize that, as I was initially a bit worried about damaging something while unscrewing. It wasn’t always easy, especially because some screws were quite tight.
I also think it’s important to mention that staying calm and taking your time during disassembly is crucial. I remember that during my first attempt, I was too quick, and as a result, a few edges got chipped, which was frustrating.
So: patience is a helpful companion. And if you notice something is stuck, it’s better to double-check whether all screws have really been removed before applying force.
Luciandi schrieb:
I also think it’s important to stay calm and take your time during disassembly.Absolutely! This kind of project can really get on your nerves when things don’t go smoothly at first. I also once felt like the screws were so tight, it was as if they were glued in place.
I also recommend using a thin putty knife or plastic scraper at spots where you pull off edges or grooves to avoid damaging the material. It’s exactly these small tips that helped me overcome my uncertainty.
Additionally: if possible, work with two people. This makes disassembling the cabinet much safer, especially with tall carcasses.
