ᐅ Timber frame construction, level 2 skim coat – breathable interior plaster
Created on: 27 Dec 2017 12:16
Baupaar2018B
Baupaar201827 Dec 2017 12:16Hello everyone,
We are building a house using timber frame construction, with Q2 level skim coating.
For the interior design, we want to use breathable interior plaster applied by rolling.
We have chosen a branded product, Knf Esiputz, in fine grain.
Since all interior walls are made of gypsum drywall panels, which are known to be very absorbent, we need to prime them.
The question is whether we can use a standard primer or if there is a better alternative. The information we have gathered is partly contradictory. What are your experiences, or what would you recommend?
Baumfachmann30 Dec 2017 19:07Hi, the primer must definitely be completely dry, possibly applying two coats, especially on the corners.
Plastering should be done at a room temperature between 18 and 22 degrees Celsius (64 and 72 degrees Fahrenheit) and avoid drafts to ensure the surface dries evenly.
Baupaar20187 Jan 2018 19:27Thank you for the professional answer!
Baumfachmann8 Jan 2018 22:35Stir the plaster well from time to time; you will develop a feel for it. Take your time, it will work out. You can also practice beforehand on a drywall panel, for example, applying with a trowel and wiping crosswise with a large damp glaze brush, etc., using only light pressure.
