ᐅ The BILLY shelf doesn’t fit into the recess – what can I do?
Created on: 26 Apr 2024 09:27
O
OSMAR35
O
OSMAR35
26 Apr 2024 09:27
I ordered a Billy shelf unit from IKEA to fit into an existing niche in my living room. Unfortunately, the shelf does not fit properly because the niche is slightly smaller than the standard dimensions of the Billy unit. The width of the niche is about 80 cm (31.5 inches), but the Billy unit is 80 cm (31.5 inches) plus approximately 1.5 cm (0.6 inches) extra space needed due to the carcass elements and side panels.
My question is: What can I do if the Billy unit doesn’t fit directly into the existing niche? Are there ways to modify the shelf without compromising its stability and appearance? Or are there alternative solutions or models that are more flexible? I would appreciate constructive advice beyond the standard dimensions, including possible on-site adjustments or suitable construction methods.
Thank you in advance!
lyndon
26 Apr 2024 10:13
In such cases, it is advisable to first accurately measure the actual dimensions of the niche and the shelf, including any irregularities and tolerances. Since BILLY units typically consist of modular carcasses with fixed external dimensions, direct trimming is difficult.
One possible solution is to lightly sand or cut the shelf from the side panels or back panels if you are skilled in woodworking – however, you should first check whether this might compromise the stability of the shelf. Alternatively, the gap between the shelf and the niche wall can be filled with narrow strips or flexible material to achieve a precise fit.
Installing a narrower or custom shelf system from a carpenter is also an option if modifying the BILLY system is not feasible.
Josefane
26 Apr 2024 10:47
lyndon schrieb:
One possible solution is to slightly sand down or shorten the shelf from the side panels or back panels, if you have the necessary DIY skills
At first glance, this might seem practical, but I consider it risky. BILLY shelves are made from pressed wood/particleboard, where the material at the edges is often less durable. Shortening can quickly weaken the structure or cause visual drawbacks.
I would rather look for a custom-built built-in shelf or at least check whether IKEA itself offers adjustable alternatives (such as GERTON shelving systems).
lyndon schrieb:
compensate the gap between the shelf and the niche wall with narrow strips or flexible material
This is the more sustainable and straightforward approach. This way, the structure remains intact and can be visually adjusted.
ju_ren
26 Apr 2024 11:05
You could place the shelf a bit deeper at the front or position it slightly angled within the niche. Alternatively, measure suitable shelves and install them separately. Or simply choose a smaller shelf.
tra_nina
27 Apr 2024 08:33
For clarification: The standard BILLY model has a width of 80 cm (31.5 inches) without any clearance. Therefore, a niche with an 80 cm (31.5 inches) width is already too tight, as wall irregularities and tolerances are always present.
IKEA also offers narrower BILLY shelves: 60 cm (23.6 inches) wide or even 40 cm (15.7 inches), which might help depending on the situation. Another practical solution is to lightly sand the sides of the shelf, but only carefully and by a maximum of 2–3 mm (0.08–0.12 inches) to avoid damaging the panel material.
It is recommended to mount the shelf to the wall using screws and anchors, which makes the shelf more stable, even if it is adjusted to be slightly narrower. Flexible spacers can help visually conceal any gaps.
todunar
27 Apr 2024 14:52
That’s brilliant! 🙂 I had the same issue once and simply cut out the back panel of the BILLY and replaced it with a thinner MDF board so the shelf fits into the recess. It’s essential to carefully smooth all edges!
I also sanded the sides of the shelf slightly at that spot—no more than 5 mm (0.2 inches). This maintained the stability, and the shelf looks like it was made exactly for the niche. It’s really satisfying to come up with and carry out solutions like this yourself! 🙂
