ᐅ The BILLY shelf doesn’t fit into the recess – what can I do?
Created on: 26 Apr 2024 09:27
O
OSMAR35
I ordered a Billy shelf unit from IKEA to fit into an existing niche in my living room. Unfortunately, the shelf does not fit properly because the niche is slightly smaller than the standard dimensions of the Billy unit. The width of the niche is about 80 cm (31.5 inches), but the Billy unit is 80 cm (31.5 inches) plus approximately 1.5 cm (0.6 inches) extra space needed due to the carcass elements and side panels.
My question is: What can I do if the Billy unit doesn’t fit directly into the existing niche? Are there ways to modify the shelf without compromising its stability and appearance? Or are there alternative solutions or models that are more flexible? I would appreciate constructive advice beyond the standard dimensions, including possible on-site adjustments or suitable construction methods.
Thank you in advance!
U
usbla
27 Apr 2024 18:19
todunar schrieb:
I had the same issue and simply cut out the back panel of the BILLY and replaced it with a thinner MDF board
This is a very good tip since the back panel of the BILLY is not load-bearing and can be replaced fairly easily.
I would add that when sanding or trimming, it is essential to pay attention to the existing braces and carcass edges to avoid compromising stability.
If you are not very confident with DIY work, it is better to consider custom-made furniture, as small mistakes during adjustments can lead to significant problems later on.
