ᐅ Stainless steel potable water pipes: what are the disadvantages?
Created on: 18 Jan 2020 18:16
Peter Hausbau
I want to install stainless steel water pipes in the new build.
We have hard water, pH value 7.67.
What are the disadvantages of stainless steel apart from the cost, the more complex installation, and possible nickel content?
Best regards, Peter
Nordlys
18 Jan 2020 19:45
Why so upset? I’m telling the OP that PE is sufficient, but if stainless steel (VA) is used, then grade 316L (4A) is required, and that is more expensive. Now it’s up to them to decide.
Specki
18 Jan 2020 19:49
I'm not annoyed.
Your posts just always come across as if only your opinion matters and no other. That's why I only pointed out that there are reasons why someone might prefer stainless steel over plastic.
You asked about that yourself.
Peter Hausbau
18 Jan 2020 20:01
hampshire schrieb:
Strange that you ask about the disadvantages and don’t seem interested in the advantages.
I’m already well aware of the advantages. That’s why I want to use them.
I just want to make sure I haven’t overlooked any significant disadvantages for me.
Vicky Pedia18 Jan 2020 20:59
Mapress, or Ode, Sunpress, and similar systems are state-of-the-art. The advantage of stainless steel is that it is highly resistant to corrosion. Both plastic and stainless steel serve their purpose equally well. One person drives a car with four rings, another one with a star. Stainless steel is very high-quality and durable. The price will also be a deciding factor.
Peter Hausbau
18 Jan 2020 21:53
One disadvantage of stainless steel is the more complex installation process. How does the Raxinox from Viega compare in this regard? From what I understand, it can be installed almost as flexibly as plastic composite pipes, right? Has anyone had experience with this system?
dab_dab
18 Jan 2020 22:33
If the choice for VA is only due to an aversion to plastics in drinking water installations (plasticizers, etc.), keep in mind that usually the pipes from the water utility to the house are already made of plastic pressure pipes.
