ᐅ Spot lighting / arrangement / quantity
Created on: 31 Mar 2021 15:04
exto1791
We are currently planning the arrangement of our recessed lights—mainly in the shower area of our bathroom.
At the moment, our contract includes 4 recessed lights at our request, but this number can of course be increased or decreased anytime (1 recessed light for concrete ceiling = €70.00).
I have attached our bathroom on the upper floor.
Shower: the full depth to the "toilet wall" is 2.10 m (7 feet), with a width of 1.00 m (3 feet 3 inches). The wall towards the door will be built up three-quarters high, meaning the shower is not fully enclosed and may still get some light since the wall does not reach the ceiling. The toilet wall is half height and has glass above it, so light also comes in here. How many recessed lights would you install in the shower, and how would you arrange them? Are 4 recessed lights really necessary here?
I have also attached our kitchen on the ground floor.
We are planning to add 2 recessed lights above the breakfast bar, plus a normal ceiling light centered in the kitchen. Does this make sense or not? The kitchen is quite long, so we assume that 2 recessed lights above the bar area would improve the lighting.
We are also considering typical recessed lighting along the stairs—see the example image attached.
What do you think about that? Is the main contractor allowed to charge the €70.00 per recessed light here as well, or is it somehow cheaper to install wall-mounted lights? Does this make sense at all, or does anyone have experience with it? Or is it ultimately just a visual highlight that ends up costing a lot?
Otherwise, we are not planning any other recessed lights in the house.
We would appreciate brief feedback on our thoughts 🙂
Kleiner 2D Badgrundriss mit Badewanne, Toilette und Waschbecken.
Offener Grundriss: Küche mit Herd, Essbereich mit Esstisch und Stühle, Diele/Eingang.
Helle Holztreppe im Treppenhaus mit Metallgeländer und Wandlichtspots.
Mycraft7 Apr 2021 10:20
That depends on the type of detector you buy. There is nothing that does not exist.
kati13377 Apr 2021 10:23
exto1791 schrieb:
200 INCLUDING motion sensor? For me, the prices mainly concern the installation and connection costs.
I still have to buy the lamps afterward as well – so I don’t necessarily want to include the motion sensor cost itself right now. Do I need to prepare anything in advance, or will anything be more expensive at the start if I want a motion sensor?
I’m not an expert on this. We had two invoice items for the motion sensor:
  • 2247 Motion sensor 180° surface-mounted - 6800 switchable - upper part Comfort II no multi-lens 1.00 125.00 125.00
  • 2384 Motion sensor B&J surface-mounted insert - 101 standard insert 6812 U 101 1.00 75.50 75.50
So a total of 125 + 75.50 = 200.50 plus VAT.
Ours has a small switch installed. If I slide it all the way to the left, it’s permanently off; in the middle position, the motion sensor is active; and in the far right position, the light is constantly on.
So basically, like a normal light switch with on/off, but with the additional motion sensor function.
However, we can’t do any fancy functions like timers or dimmed light at night, or anything like that.
