Hans123-11 Feb 2014 11:18Insulation is also very important when planning a house. On one hand, you want lots of natural light and large doors, but on the other hand, these are often the points where a lot of heat can escape from the house. Of course, there are good insulated windows available, but what about the doors? What kind of front door, garage door, and possibly back door have you installed? What criteria did you use to decide?
Regards
Hans
Regards
Hans
Hi Hanns, that’s a good question you’re asking, and it’s probably overlooked by many.
Yes, there are doors that meet your requirements, for example:
[h=1]Hörmann Aluminum Entrance Door TopComfort[/h]double-glazed with thermal insulation
Many colors available
This door is also filled with rigid foam on the inside, providing good thermal insulation.
You can find similar solutions with uPVC windows as well.
Kurt1985-110 Feb 2014 08:12I had aluminum front doors installed. The main entrance has double doors, and a smaller door was installed for the basement. The thermal insulation is exceptionally good.
Hans123-110 Feb 2014 11:25Thank you, I guess I’m not quite up to date on the insulated door options available now.
So far, we have only had solid wooden doors, and the seals between the doors and the frames were not always completely tight.
I always have an image in mind from a TV program I once saw, where a house was examined with a thermal imaging camera.
The red areas, which clearly showed heat loss, were always around the door and window frames.
Richard-111 Feb 2014 11:50The front door should be wide. This is especially advantageous when furniture or similar items are delivered. Aluminum doors are a good option and are available in various colors.
