ᐅ Should concrete paving slabs (5 cm thick) be compacted with a plate vibrator after installation?
Created on: 30 Aug 2019 21:38
JoergJ
JoergJ
30 Aug 2019 21:38
I have created a foundation using concrete paving slabs (50cm x 50cm x 5cm (20in x 20in x 2in)) laid on a bed of gravel. My question is whether I should compact the slabs any further after grouting, or if this is unnecessary and might even cause the slabs to crack given their size and material.
Thank you
Regards,
Jörg
drhaensen
1 Sep 2019 16:45
Hello Jörg,
What kind of load will the “foundation” have to bear? And how compact is the gravel bed?
I’m planning something similar for the upcoming season.
I want to use the slabs as an alternative to a poured concrete slab.
I will be placing a hot tub weighing about 1 ton (1,000 kilograms) on it. I would definitely compact the base if it will be heavily loaded.
This year, I laid paving slabs in the yard as a regular walkway, using slabs measuring 30 x 30 x 4 cm (12 x 12 x 1.5 inches). I did not compact the base for that. There, I removed the old paving and raised the already compacted gravel bed by 3 cm (1 inch).
fragg
2 Sep 2019 08:48
JoergJ schrieb:
I have created a foundation using concrete paving slabs (50 x 50 x 5 cm (20 x 20 x 2 inches)) laid on a gravel bed. My question is whether I should compact the slabs again after grouting, or if this is unnecessary and the slabs might even break due to their size and material.
Thanks
Jörg
No, they will break.
illusionslos
27 Sep 2019 12:25
I also used these panels for my garden house. Lay them down, align with a rubber mallet/level, and you’re done. They are so heavy that they stay perfectly in place on their own.
