ᐅ Seal for concrete
Created on: 4 Aug 2011 10:40
Gianna-1
4 Aug 2011 10:40
Hi
I would like to embed something from our family into our foundation (made of concrete) when it is poured. Apparently, there are special containers for this. Unfortunately, I don’t know the technical term for them (someone mentioned “plombens”). I also don’t know where to buy something like this. Can anyone help me?
That would be very kind.
Best regards, G
MODERATOR
4 Aug 2011 14:05
Hello Gianna,
This is called a "time capsule"; it is often buried under the foundation — this way, it is more likely to be found again if the house is demolished far in the future. If the capsule is cast into the foundation, it is more likely to be overlooked and lost during demolition work.
There is no specific market for such "time capsules."
However, you can have a container made by a metalworker or locksmith. You should choose a metal that hardly oxidizes; stainless steel would be suitable. The easiest way is to seal one end of a stainless steel pipe (welded) and, after placing the keepsakes inside, either screw the other end tightly closed or weld it as well — possibly designed with a predetermined breaking point. To protect the contents from moisture, it is advisable to seal the items inside a plastic bag within the capsule.
A tightly closing box is also conceivable. It is best to discuss this with the craftsman.
Gianna-1
4 Aug 2011 15:44
Thank you very much for the prompt response.
Gianna
