ᐅ Sealing and insulating the base coat plaster
Created on: 15 Apr 2017 15:51
FranksHaus68
FranksHaus68
15 Apr 2017 15:51
Hello, since I am building a new terrace, the base plaster will extend 20cm (8 inches) in height. Because the base plaster (painted with some older paint showing wear) will be in contact with gravel or frost protection, I plan to apply bitumen coating to the plaster and then install a dimpled membrane. My question is whether this approach is correct. I would like to thank you in advance for any suggestions and solutions.
Regards, Frank
Nordlys
17 Apr 2017 21:14
Bitumen is fine. What do you mean by dimpled membrane (also known as drainage membrane or studded membrane)?
Bieber0815
18 Apr 2017 09:07
The old paint will likely need to be removed beforehand.
Nordlys
18 Apr 2017 21:33
If it is solid, not necessarily. Only what is flaking off.
