ᐅ Replacing IKEA Malm Drawer Slides – Step-by-Step Guide?
Created on: 30 Jan 2021 07:52
Sophia0
Sophia0
30 Jan 2021 07:52
I have an IKEA Malm bedroom furniture set, where the drawer slides have become damaged or worn out from frequent opening and closing. I would like to replace the drawer slides to restore proper function. Although I found some information online, there is no complete step-by-step guide specifically tailored to the Malm dresser.
My specific question:
How do I properly replace the drawer slides (that is, the metal or plastic runners on the sides of the drawer) on an IKEA Malm dresser? What tools do I need, what is a sensible order of steps, and what should I pay special attention to in order to ensure smooth and stable operation afterward?
I am also open to suggestions regarding sources for replacement parts (original IKEA components or compatible alternatives) and advice on troubleshooting if the drawer does not run smoothly after replacement.
Thanks in advance for any help!
Laurence
30 Jan 2021 10:34
Hello Sophia0,
I can gladly provide you with a detailed guide on how to replace the drawer slides on the MALM dresser.
First, you will need a Phillips screwdriver (PH2) and preferably a small pair of pliers. The MALM drawers usually have metal or plastic runners that are screwed to both the drawer and the cabinet.
Detailed steps:
1. Pull the drawer out completely and carefully remove the rear plastic stopper piece (usually fixed with screws).
2. Then, loosen all visible screws on the drawer slides attached to the drawer.
3. Carefully detach the drawer slides – this may require some patience, as clips or snap locks may be involved.
4. Remove the screws on the guide rails inside the cabinet as well.
5. Attach the new slides, making sure the sliding direction and locking mechanism are correct.
6. Reinsert the drawer and check that it moves smoothly.
Regarding sources: It’s best to order original parts directly from IKEA or use specialized spare parts retailers. Compatible alternatives may vary, with dimensions usually being the key factor.
An important tip: Before installation, carefully check the alignment of the rails. Slight misalignments can cause the drawer to stick.
I hope this helps! If you would like pictures or further explanations for any steps, feel free to ask.
nubar
30 Jan 2021 12:07
Hello Sophia0,
Laurence has summarized the essentials well. I would like to add that MALM drawer slides often consist of two parts: the fixed rail attached to the cabinet and the moving rail attached to the drawer. It is important that when removing the drawer, you first take out the entire drawer and do not forcefully detach the rails from the cabinet to avoid damage.
This is a key point! Sticking often happens because the screws were not tightened evenly during installation or the rails were not installed exactly parallel within a millimeter.
If you buy replacement parts, I recommend choosing the original drawer slides since aftermarket versions often do not fit precisely enough. Alternatively, you can switch to "soft-close" versions, which usually have the same mounting dimensions and offer more convenience.
If you experience problems after replacement, check the drawer’s level inside the cabinet using a spirit level or by ensuring flush contact, as a tilted drawer often causes operating issues.
Best regards!
V
vinpau
31 Jan 2021 08:15
Hey Sophia0 and everyone else reading!
Wow, "Replacing IKEA MALM drawer runners – instructions?" That’s a great topic, because that dresser is really practical, but the runners can be quite annoying when they stick or get too noisy!
Laurence schrieb:
Install new rails, make sure the running direction and locking function are correct.
That’s exactly so important! Those parts have to fit properly, or it’s not fun at all. I recently replaced the drawer runners on my MALM and can tell you: there’s nothing more satisfying than the smooth, quiet glide after the replacement :-)
My tip: take your time and lay everything out neatly before you start. Sort all the parts—that makes assembly easier. And be careful when removing the old rails, as not all come off easily—sometimes a gentle lever with a screwdriver helps.
One more thing: when you have the new runners, try testing one drawer completely before replacing them all. That will save you trouble!
Good luck and let us know if you run into any problems 🙂
BLAKEO
1 Feb 2021 14:41
I would like to offer a somewhat more critical perspective. The question "How do I properly replace the drawer slides on an IKEA MALM dresser?" is complex because the term "properly" depends heavily on the goal.
Laurence schrieb:
First, you need a Phillips screwdriver (PH2) and ideally a small pair of pliers.
These are standard tools, but I believe it is necessary to specify the screw sizes as well, so you use the correct tools right away and avoid damaging the screws. Equally important are precautions to protect the material, for example when using leverage tools, to prevent damage to the surface.
nubar schrieb:
Delays often occur because the screws were not tightened evenly during assembly or the rails are not perfectly parallel within a millimeter.
This is crucial: installation precision is key. However, the drill holes on IKEA products are fixed, so this is only possible to a limited extent. The question then arises whether upgrading to higher-quality drawer slides, possibly from third-party suppliers, might be worthwhile. Such adjustments do require some craftsmanship skills.
In conclusion, the instructions should also mention the possible need to readjust certain components like stoppers or dampers after the replacement.
Regards.
