ᐅ Repairing a BILLY Shelf with Wood Glue – Is It Reliable?
Created on: 15 May 2018 08:47
kinpa
I have a Billy bookshelf with a loose joint. My question is whether it’s possible to permanently repair an IKEA BILLY bookshelf using simple wood glue, and if the glue will really hold at the joints, especially under load and considering the typical particleboard components.
Maybe some of you have experience with this and can say whether this is a reliable repair or if the structural strength is significantly compromised.
I’m thinking about sanding the affected edges first, then gluing them with wood glue, and possibly adding a few screws for extra security.
What do you think? Is this a “safe” solution or more of a half-hearted repair that will fail again soon?
Thanks in advance for your assessments and tips!
benonon
17 May 2018 09:34
[quote=kinpa, post:0, member: XXX]Whether a BILLY shelf can be permanently repaired using simple wood glue and whether the glue at the joints really holds, especially under load and considering the typical particleboard parts.[/quote]
I would like to approach this from a more technical perspective: Particleboard panels are made from wood chips bonded with synthetic resin – often, the bonding does not achieve the same durability as solid wood. The cut edges quickly absorb glue, which makes bonding more difficult.
To maximize adhesion, the surfaces to be glued should be pretreated with wood glue or wood hardener to prevent excessive absorption and swelling.
Furthermore, using screws (ideally combined with dowels) is a reliable method to strengthen the assembly without damaging the wood.
Regarding the glue joint alone: it holds if executed well – but one should consider the higher flexion and bending stress of particleboard and not rely solely on wood glue.
Kinbu
17 May 2018 16:12
Sepele schrieb:
Particleboard absorbs moisture quickly, which can cause swelling.
I would like to expand on this: If the glue is applied too wet and the clamp does not maintain consistent pressure, the board absorbs too much moisture and swells at the glue joint, making the connection unstable.
For those who are unsure: Be sure to use an appropriate clamping method, such as screw clamps with soft pads, to distribute the pressure evenly, and leave the freshly glued shelf undisturbed for at least 24 hours.
blapau schrieb:
Additional reinforcement with screws or dowels does no harm, especially if the shelf is frequently moved or loaded.
In my view, this is the best practice: Repairs made with wood glue, done correctly, are durable in the medium to long term, but for maximum security, add screws as reinforcement.
reni45
18 May 2018 10:51
Wood glue alone works if everything fits perfectly. But if the shelf will be loaded, it’s better to also use screws. This helps prevent it from coming loose again.
