ᐅ Reinforcing a Billy Shelf on the Side – Which Components Are Useful?
Created on: 11 Dec 2017 08:23
Plogu57
Hello everyone, I’m considering reinforcing my Billy shelf on the side because I noticed it starts to wobble slightly when there’s a bit more weight on the side. The question is: which components are effective for making the shelf more stable without significantly changing its appearance or using invasive methods? I’m thinking about metal brackets, additional cross braces, or maybe wooden strips. Does anyone have experience with which method works best if you want to keep visible screws and drilling to a minimum, but still achieve a noticeable improvement in stability? Thanks in advance for your advice!
Regarding the components: Diagonally installed cross braces have been proven to increase the stiffness of a frame. Compared to horizontal bracing, the critical shear force is reduced, resulting in significantly less lateral movement in the shelf.
Material recommendation: Hardwood with a minimum thickness of 18 mm (0.7 inches) or metal profiles with at least 1.5 mm (0.06 inches) wall thickness. Fastening should be done with wood or metal screws that are long enough to provide adequate grip.
Adhesive tapes or self-adhesive metal braces do not provide lasting stability under loads of 20 to 30 kg (44 to 66 lbs) per shelf. They are more suitable for cosmetic adjustments or light support.
FREDRICK schrieb:
Adhesive tape or self-adhesive metal braces do not provide permanent stability for loads of 20 to 30 kilograms per shelf.\Exactly! A good tip: you can stabilize not only the shelf board but also the entire shelving unit. Metal brackets under the board are a practical solution here. Small, unobtrusive, and they provide solid support.
Also, if you’re planning to do some DIY, I would recommend considering an additional sturdy back panel – it often makes the biggest difference.
I'll add my two cents :-)
I installed side reinforcements on my Billy as well, using special stainless steel furniture brackets that are very flat. I mounted them on the inside, so they are hardly visible, and since then the shelf has been rock solid 🙂
If you want, you can also cover the screws with wooden dowels – they become hardly noticeable after screwing in and hold very well.
One more tip: check the back panel too – sometimes the nails or screws there are loose. A sturdy back panel, along with the side reinforcements, provides most of the stability.
