ᐅ Custom-fitting and securely installing Ikea METOD cabinets under sloped ceilings
Created on: 9 Dec 2016 19:23
Rinaldo
Rinaldo
9 Dec 2016 19:23
I am currently facing a challenging task: I want to perfectly fit my Ikea METOD kitchen cabinets under a sloped ceiling and securely fasten them for the long term. The slope in the room is quite steep, so the standard cabinet height definitely cannot remain unchanged – they need to be adjusted in height.
Does anyone have experience with cleanly cutting or modifying METOD cabinets without compromising their stability?
I am also interested in how you best attach the cabinets to the sloped ceiling so they don’t wobble or come loose over time, especially when storing heavy items. Are there specific brackets or mounting methods you would recommend?
Perhaps you also have tips on materials or tools that have proven particularly useful, or general advice on how to approach working with sloped ceilings using METOD cabinets.
Thanks in advance for your advice!
leomo
9 Dec 2016 21:07
Hey Rinaldo,
great topic you brought up! The METOD cabinets are really flexible options, but working with sloped ceilings can get tricky—especially when it’s more than just a small slope.
Regarding cutting: I’ve done this with a jigsaw, always very carefully, and then smoothed the edges afterward with sandpaper. It’s important to fully disassemble the cabinets beforehand and only modify the side panels. Leave the fronts and backs untouched to maintain stability.
For mounting on the slope, I used metal brackets, which I secured to the wall with longer screws, and added small reinforcing strips on the inside of the cabinet. This keeps the structure very solid, even when you put a heavy pan inside.
A little tip: use appropriate shims as well, so the cabinets don’t twist or tilt on the slope. And don’t forget to check everything thoroughly with a spirit level.
Good luck, it will definitely turn out great!
pinbo
10 Dec 2016 08:42
Rinaldo schrieb:
Does anyone have experience with cutting or modifying METOD cabinets carefully without compromising their stability?
In principle, adjusting the height of METOD cabinet side panels is possible, but you should plan very carefully which parts to modify. The side panels are load-bearing, while the fronts and back panels mainly provide stabilization. Cutting the side panels always carries the risk of altering the load distribution and making the furniture unstable.
Therefore, my recommendation is that any modification should be accompanied by reinforcement. For example, you can glue or screw strips made of plywood or metal profiles inside the cabinet for additional support. With sloped ceilings, it is also important to secure the mounting points firmly into load-bearing masonry, since the leverage increases due to the slope.
Regarding fasteners: standard brackets may be sufficient if correctly sized and installed, but additional safety can be achieved with special fittings designed for sloped ceilings or angled mounting.
Are there exact measurements of the roof slope? That information could help provide more specific advice.
Brian
10 Dec 2016 13:56
pinbo schrieb:
Are there exact measurements for the roof slope?
Exactly, that would be important. I have installed METOD cabinets in various situations with sloped ceilings myself. It’s crucial to first create a template system or a precisely measured cardboard mock-up to accurately capture the slope. This helps avoid unpleasant surprises during installation.
For secure fastening: Screwing into the structural beams is always better than just into drywall or wooden battens. If available, use anchors suitable for the wall type.
Additionally: IKEA offers flexible connector brackets for METOD that allow for some adjustments—this might be an option if the slope is not consistent throughout.
If space is very tight, you can also install trim strips above the completed cabinet row to visually cover unevenness and provide extra stability.
In summary: Measure the fit precisely, only shorten cabinet sides with care, reinforce inside, and fasten securely to load-bearing walls.
