ᐅ Ikea Metod: How can I accurately fit kitchen units under sloped ceilings?
Created on: 21 May 2024 10:13
Fuda53
Hello everyone, I have a challenge planning my Ikea Metod kitchen: How do I fit kitchen units perfectly under a sloping ceiling?
Specifically, I’m looking at how to install base cabinets and wall cabinets beneath a slanted ceiling without gaps, while ensuring the furniture remains stable despite the roof slope. I also want to know the best way to adjust the top edge, whether special trims or cuts are needed, and which angles should be measured to ensure a really precise installation.
Has anyone had experience with Metod kitchens under sloping ceilings? What tips or Ikea products are especially useful? And what’s the best approach if you don’t have access to industrial cutting machines? Any advice is much appreciated!
farGlen
21 May 2024 12:31
You can use the height differences; open shelves are often practical in sloped ceilings. Front adjustments are easily possible, but with Ikea Metod, the shelves are more stable than you might think. Simply fasten them, and they will hold.
Nabla64
21 May 2024 12:50
Regarding height variations: Ikea Metod offers standardized cabinet heights, that is correct. If you want to combine different heights, plan the transitions carefully.
Important:
- Align surfaces precisely
- If necessary, equip fronts with trim frames.
Custom front adjustments are possible but more complex. It is better to use cabinets in standard heights and visually balance the slope with cladding or small intermediate shelves.
Open shelves are less stable than closed cabinets, so pay attention to steel fastenings.
likuken
21 May 2024 13:14
Nabla64 schrieb:
Front modifications are possible but more complex.
This is often where the problem lies: many overestimate their welding skills when customizing fronts. Ikea designs are standardized, and adjustments take time and patience.
Why not just hire a carpenter? That way, you avoid hassle and get a proper result. Considering the time and frustration involved, it can sometimes be more worthwhile than doing it yourself.
dijan
21 May 2024 13:45
likuken schrieb:
Many people overestimate their welding skills when working on custom fronts.
Haha, that’s always the case! 😅 But hey, doing it yourself is a learning experience.
Maybe so-called “gap fillers” or edge trims, which can be used flexibly, might help. And for open shelves in the ceiling area: it’s better to keep the weight down to maintain stability.
So: doable and enjoyable! 👌
Davidleo
21 May 2024 14:07
Fuda53 schrieb:
Is it possible to simply vary the cabinet heights and then adjust the fronts accordingly, or does that get too complicated?
Absolutely, you can do that! I did the same in my home: combined different cabinet heights and used custom-fit fronts. It might sound complicated, but if you take your time, it’s definitely doable.
Especially with sloped ceilings, this creates great custom solutions!
Open shelves are also very practical and airy, especially in tight spaces. Just make sure to secure the shelves well – then they’ll hold up without any issues.
Don’t get discouraged, it will look fantastic! 😎
Fuda53
22 May 2024 09:12
Thank you for the contributions so far!
I have now started measuring angles and heights multiple times and made a cardboard template, which already makes the work significantly easier.
However, I’ve noticed that the angles are not consistent—the roof slope is slightly uneven, which makes cutting more difficult.
Do you have any recommendations on how to handle such irregular angles with Ikea Metod? Should I keep the fronts flexible or accept small gaps?
Perhaps someone uses flexible trims or moldings that I should take into account?
