ᐅ Pay for geothermal deep drilling immediately or after heating system inspection?
Created on: 27 Nov 2022 18:17
Z
ZwölfSieben
Z
ZwölfSieben
27 Nov 2022 18:17
I’m a bit confused about the best timing to pay the deep drilling company in order to avoid implicit acceptance.
Situation:
  • The deep drilling for the geothermal heat pump has been successfully completed, ball valve fittings installed in the technical room
  • Invoice has been received
  • Connection to the heating system and therefore testing whether the probes function properly will only be possible in a few weeks due to screed drying, heating system completion, etc.
What would be the best approach regarding payment?
  • Pay immediately with the risk that the warranty period starts without the heating installer being able to fully inspect, or
  • Pay a deposit of 80%, with the remaining 20% after acceptance
  • Any alternative suggestions?
Thank you very much!
Peter.
O
Osnabruecker
27 Nov 2022 19:07
What have you agreed upon?
One-sided arrangements will likely lead to discussions with the drilling team.
Fuchur
27 Nov 2022 20:16
What exactly do you expect to identify as defects with the heat pump connected, which would also be relevant throughout the warranty period?
And what responsibility does the contractor have for the fact that you currently cannot carry out the tests you want? This is your area of responsibility.
NatureSys
28 Nov 2022 02:22
One option is to transfer the full invoice amount as an advance payment. This way, the contractor is satisfied because they have received their money, and you have not confirmed the validity of the invoice.
Z
ZwölfSieben
28 Nov 2022 11:16
Fuchur schrieb:
What do you expect to identify as defects with the heat pump connected that would still be relevant for the entire warranty period?
For example, leaks in the ground loop?
Fuchur schrieb:
And how is the contractor responsible if you currently can’t perform the tests you want? That’s your problem area.
That convinces me. If my heat pump is only installed in 3 years, the drilling contractor can’t be held responsible. Especially since they verified the system’s performance conclusively with the drilling. That’s completely different from the screed, where defects can only become apparent after the drying phase.
@all: Many thanks for the feedback!
Fuchur
28 Nov 2022 11:19
ZwölfSieben schrieb:
For example, a leak in the brine pipe?
That’s what I meant. You will notice that immediately within one month. It doesn’t matter if the warranty is then shorter by one month.
