ᐅ Painting the KALLAX Back Panel for a Better Look – Any Experiences?
Created on: 20 Apr 2023 09:12
Editben
Hello everyone, I want to customize my KALLAX shelves a bit and am considering painting the back panels to improve their appearance. Has anyone here had experience painting the KALLAX back panel? How well does the material (thin cardboard) handle paint—are there any issues with adhesion or warping? I plan to use acrylic or chalk paint and am also thinking about applying a primer. Are there any tips for preparation, painting technique, and durability? It would also be helpful to know if the back panel remains stable afterward or if it’s better to use alternatives. I look forward to your opinions and experiences!
Gino38
21 Apr 2023 09:27
Typically, I use an acrylic primer for such thin cardboard panels, which directly prevents moisture from penetrating and seals the surface. This avoids swelling and warping of the material.
I recommend a drying time of at least 4 hours between priming and painting, sometimes overnight – depending on the product. For multiple coats, apply thin layers and allow each to dry thoroughly.
In principle, the load-bearing capacity of the back panel remains unaffected. However, the material is not designed for heavy loads by nature. For higher stability, MDF is the better choice.
klo61
21 Apr 2023 10:48
Hello Editben!
I really like your idea of painting the back panel because when the KALLAX shelf is freestanding, a nicely designed back panel can be a real eye-catcher.
Since the material is quite thin and absorbent, I highly recommend the following steps: lightly sand it first, then apply a primer (for example, a sealing primer) that protects against moisture and improves paint adhesion.
Acrylic paint is ideal for this, as it is flexible and durable. After painting, I would suggest applying a clear protective varnish for better durability – this also helps the paint withstand cleaning.
Regarding drying times: always let each layer dry fully before applying the next, otherwise the back panel may warp or the paint could peel. I would advise against using inexpensive hardware store paints; investing in quality products pays off here.
Do you have specific colors or patterns in mind? I can also offer tips on application if you like.
Elodie
21 Apr 2023 12:05
Just as a supplement to @klo61: I once had the problem that the back panel warped slightly due to layers of paint that were too thick. So really apply several thin layers! And for a better feel: using a paint roller instead of a brush can make the surface a bit smoother.
One more practical tip: it’s best to test the color on a small leftover piece beforehand, if you have any left from the shelf. You never know if the paint looks exactly the same on the cardboard as it does on paint swatches 🙂
PLOMA
22 Apr 2023 07:19
Good morning everyone, here are a few specific recommendations:
For primer, I have used products like "Tiefengrund universal" from various brands. It penetrates well, stabilizes the surface, and makes it water-repellent. In the past, I have also recommended clear varnish as a protective layer, but for back panels, it is often not necessary if the shelf is not constantly loaded or wiped.
You should allow at least 6 hours of drying time between each coat, preferably overnight. Make sure to store the back panel horizontally during this time to keep it straight and prevent warping.
Hector schrieb:
I am curious whether painting the back panel actually adds any aesthetic value
That obviously depends on the location, but if back panels are visible, even a simple colored paint on plain particleboard makes a huge difference.
If you have any further questions about the exact materials or tools, feel free to ask.
