ᐅ Optimal Temperature for Refrigerator and Freezer
Created on: 20 Jun 2023 10:25
FrankChief
FrankChief
20 Jun 2023 10:25
what is the optimal temperature to set for the refrigerator and freezer?
I have read that 5°C (41°F) or 7°C (45°F) is recommended for the refrigerator.
For the freezer, -18°C (0°F) is considered optimal.
What would you say are the best temperatures?
WilderSueden
20 Jun 2023 10:39
FrankChief schrieb:
18 degrees would be ideal for the freezer
I would put a minus sign in front of that.
We keep the fridge at +8, which is enough for milk and so on. Although we also have two 0-degree compartments in the fridge.
FrankChief
20 Jun 2023 10:57
WilderSueden schrieb:
I would put a minus sign in front.
Otherwise, it would be a bit wrong.
We have our refrigerator set to +8, which is enough for milk and similar items. Although we also have two 0-degree compartments in the fridge.
Our refrigerator is currently set to 7°C (45°F), but we do not have a 0-degree compartment.
I only read that the European Union recommends 5°C (41°F), but that 7°C (45°F) should be sufficient here.
That’s why I wanted to ask how you manage this and what would be optimal (regarding food storage and energy consumption).
Is -18°C (0°F) suitable for a freezer?
Mahri2320 Jun 2023 11:10
FrankChief schrieb:
Freezer at -18 degrees okay?
Yes, that’s fine. I have it set the same way. And the refrigerator at 7 degrees. We also have Biofresh compartments. You just need to pay attention to the humidity supply, as they have an adjustable lid installed.
X
xMisterDx
20 Jun 2023 23:13
My refrigerator is set to 4°C (39°F), and the freezer compartment to -22°C (-8°F). If you have a separately temperature-controlled 0°C (32°F) zone, you can set the rest of the fridge to 7°C (45°F), yes.
If not, the 0°C (32°F) zone will only be about 3-4°C (5-7°F) cooler than the rest of the fridge. So at 7°C (45°F), the cooler zone is really around 3-4°C (37-41°F), which can be too warm for fresh meat.
Energy consumption shouldn’t matter at this point. If food spoils every week, that’s much more expensive than setting the fridge 2 or 3 degrees colder.
Besides, Coke, beer, and shandy simply taste better at 4°C (39°F) than at 7°C (45°F). And if my fridge uses maybe 50 kWh more per year running at 4°C (39°F) instead of 7°C (45°F), I consider that a small luxury worth having.
What’s far more important for energy use is following the manufacturer’s recommended clearance from the wall. Too little or too much space increases consumption.
