ᐅ Older building constructed around 1970, no basement, replace or enlarge windows?
Created on: 2 Apr 2025 13:09
Z
Zoe SommerZ
Zoe Sommer2 Apr 2025 13:09I would like to replace the old wooden window with a patio door, which means the opening will be enlarged downward by about 50 cm (20 inches). This way, the crack would partially be covered. Is this possible? I would appreciate any advice!
Z
Zoe Sommer2 Apr 2025 17:17So the window is not as crooked as it appears in the picture. My question is more whether it is possible to extend the window downward, considering the structural stability and the crack. I have no expertise in this matter.
Zoe Sommer schrieb:
My question is more whether the window can be extended downward, considering the structural stability and the crack. Answer from Radio Eriwan: in principle, yes. The structural integrity is essentially not affected if the window opening is simply extended below the sill. However, the crack will then just be "taken away" without addressing its actual cause. For more precise advice, more detailed knowledge would be needed.
Zoe Sommer schrieb:
My question is more about whether it is possible to extend the window downward, considering the structural stability and the crack. I have no knowledge in this area. Most likely yes. There is already a lintel above the window.
Z
Zoe Sommer3 Apr 2025 10:42Thank you very much for your replies! I’m very pleased.
