ᐅ New construction of a single-family house with 150 sqm of living space, Saarland
Created on: 29 Apr 2021 16:04
chrisOo
I am planning to start a new build in Saarland this year.
The exterior dimensions of the house will be approximately 9.5 x 10.5 meters (31 x 34.5 feet). I wanted to share my floor plan with you and ask if you have any opinions. However, the plans currently have dimensions of 9 x 10 meters (29.5 x 33 feet).
My first idea is to remove the wall next to the staircase in the kitchen and create a 3-meter (10 feet) kitchen island parallel to the kitchen units along the right exterior wall.
Upstairs, the walk-in closet should be larger and get a connecting door to the bathroom. A garage with an access door will be added in front of the utility room.
Regarding the site plan: the house will actually be located behind the house with number 84, not as shown in the drawing. House number 84 will be demolished beforehand.
Thanks in advance.
Christoph
Grundriss eines Hauses mit Diele, Wohnen/Essen, Küche, Büro, Bad, HWR/Technik und Treppe.
Grundriss eines Obergeschosses mit Zimmern 1–3, Galerie, Schlafzimmer, Bad und Ankleide.
Lageplan eines Grundstücks mit roter Grenze; pinkes Gebäudeteil in der Mitte.
Myrna_Loy
6 May 2021 11:37
chrisOo schrieb:
Thanks for giving me relationship advice now; I actually didn’t expect that here in the forum.
So now you’re also a financial expert and you know how much the materials and the main cost factor—labor—cost me? Considering how poorly my questionnaire was, you seem to know a lot about me.
Where exactly am I giving relationship advice?
And you don’t need to be a financial expert to know that 350,000 euros is not enough for 200 m² (2,150 sq ft) of high-end living space. 1,750 euros per m² (about 163 USD per sq ft) is insufficient even in Saarland. Anyone planning a masonry pool should be aware of that.
vonBYnachSH6 May 2021 11:46
A completely different idea: how about having a proper entrance vestibule instead of a pool? The pool can always be added later... Take a look at the Variant 25-192 by Hanse Haus; the vestibule is brilliant and very bright. Then you could easily rotate the staircase back, and you wouldn’t enter directly into the stairs from the front door.
chrisOo
6 May 2021 11:52
Hello [B]vonBYnachSH,
sure, in principle that is an option. It doesn’t look bad in the house design you suggested either.
But the plan is actually to keep the floor plan relatively simple, without any “attached” elements.
Baranej
6 May 2021 12:01
haydee schrieb:
Having children visit wouldn’t bother me. I find dirt on the floors worse. After all, you deal with dirt your whole life, but children visiting in the evenings only lasts for a few years.
Of course, both have their pros and cons, which everyone has to weigh for themselves. But the less you engage with the issue personally, the more likely you are to accept suggestions without critically questioning or considering them yourself. So I just want to encourage going through daily routines again. From my point of view, this clearly includes the phase of having children visit, which should be considered both from your own perspective and from the children’s perspective.
P.S. I also prefer the threshold design in the living area.
haydee
6 May 2021 12:18
The entrance vestibule is really well designed as it has been implemented here. We saw something similar in a show home and it has been on our wish list ever since.
driver55
6 May 2021 12:46
I find this porch awful, and the extra square meters in front of the house are certainly more expensive than inside the house.
If you already plan with a “square and practical” approach, I wouldn’t want a “wart” on the house.
