Hello dear house building enthusiasts,
I would like to convert the attic (2nd floor) of an older building (built in 1974). When the house was constructed in the 1970s, the builder already planned a floor layout for the attic, knowing that it would be converted a few years after completion.
Unfortunately, life got in the way and it was never converted. For the past 45 years, it has been used as a “luxury storage attic.” As you can see from the two floor plans, there is a balcony, several skylights, and also regular windows. I have attached the current state (Ist-Stand_2018.jpg). As you can see, no walls have been built yet.
I reconstructed the originally planned layout (see attachment “Ursprünglicher_Grundriss.jpg”) from the old documents and redrawn it. Unfortunately, I am unsatisfied with this layout for the following reasons:
I have already put a lot of thought into this but haven’t found a satisfactory solution. I have attached one of my drafts (Grundriss_Neuentwurf.jpg). In this version, I like the placement of the kitchen, dining area, and bathroom very much, but I have the following issues:
In general, I have a question:
The apartment measures 107 m² (1150 sq ft) calculated according to living space regulations. Is it common for a size like this to accommodate 2 children’s bedrooms plus 1 master bedroom, or is it more usual nowadays to have 1 child’s bedroom and 1 master bedroom?
Since the apartment is not intended for me, I have no personal preferences.
Thank you in advance for any help and ideas!
Flasher
- The kitchen was also meant to serve as a dining area (typical open kitchen). Due to the kitchen’s position under the sloped roof, it is undersized. It was intended to place a table for 3 people in the kitchen.
- A child’s room can only be accessed via the common staircase, not through the apartment itself. That is a no-go for me.
- I would have liked a combined living and dining area.
- I can’t find a satisfactory way to place the sofa.
- I would have liked to use the entire width of the balcony for the living room. Now, I placed a bedroom in half of the balcony space and would even have to remove the door-window combination to the balcony.
Flasher
Living spaces require a second emergency exit (through a window). This is not provided by double casement windows. But there is a balcony in the living room. Isn't that sufficient?
Hello everyone!
I have now updated my sketch with more detailed measurements of the walls, windows, elevation lines, and roof slopes. Additionally, I have marked all four cardinal directions.
@ypg:
Screed:
You’re right, the screed and ceiling need to be constructed as well. I would estimate at least 20cm (8 inches) of “height loss,” okay?
Roof pitch:
I’ve indicated this on the sketch: 29.2 degrees
Living area
No, I left out the balcony. It has about 12.5m² (135 sq ft). But you’re also correct here—I didn’t subtract the walls when calculating the living area. Personally, I prefer to create a nice apartment rather than squeezing out the last square meter at the expense of attractiveness.
Dormers:
I had the idea of dormers about six months ago but was unsure about the potential costs and whether the structural calculations would allow for a dormer. Certainly, a very valuable point that would enhance the living space.
Flasher
@ypg:
Flasher
kaho674 schrieb:
The balcony is in the living room. Isn't that enough? I am a complete layperson on this topic, but the balcony faces the street. That means I could imagine it being accepted as a second emergency escape. Firefighters could easily access the balcony using a ladder.
Regarding dormers, I would recommend consulting a structural engineer. To my knowledge, the size of all dormers (or the single dormer on one side) should not exceed one-third of the total length of the roof surface. This is already a limitation. Among people I know who have added dormers later, no structural issues have occurred.
You should, of course, be aware that such a modification will significantly affect the exterior appearance. And you need to consider whether that is what you want.
The ridge line confuses me. Is the ridge offset?
