ᐅ My pet sleeps in the KALLAX and always leaves hair behind – how can I clean it?
Created on: 21 Apr 2021 19:37
Maximusk52
Maximusk52
21 Apr 2021 19:37
I have the following problem: My pet (a medium-sized, long-haired tomcat) has gotten used to sleeping in the IKEA KALLAX shelf. That wouldn’t be an issue in itself since I have cleared the shelf specifically for his resting place. However, he constantly leaves a lot of hair there, which is very difficult to remove because the surfaces of the KALLAX are quite open and textured.
I have already tried the usual methods – damp cloths, vacuum cleaner with upholstery attachment, lint roller – but none of these really provide a lasting solution, as the hair gets stuck in the corners and edges.
Does anyone here perhaps have tips or even specific cleaning products or tools that work well to remove pet hair quickly and thoroughly from the KALLAX?
It is important to me that the method is as gentle as possible on the furniture and leaves no residue or scratches. Maybe someone also has experience with anti-hair tools that work well on such open shelving systems?
I would really appreciate your advice, as this otherwise becomes quite annoying in the long run! Thanks in advance.
COLEBAR
21 Apr 2021 20:09
I recommend slightly dampening a rubber glove and then running it over the surfaces. It attracts hair very well and is gentle on the material. Alternatively, an electrostatic brush also works.
Good luck!
Palenar
22 Apr 2021 08:44
Hello Maximusk52,
Your question is well considered, as you clearly describe both the condition of the shelf and the type of dirt. This makes a precise recommendation possible.
Basically, with textures like KALLAX, which feature edges and open compartments, several methods combined work best:
1. Dry vacuuming: Use a handheld vacuum with a brush attachment. It is important that the suction is not too strong to avoid scratches. Vacuums with turbo brushes are less suitable for this.
2. Rubber or silicone brushes: These attract hair, especially if you first gently remove or gather the hair by hand. For example, there are special brushes for pet hair that work very well on furniture too.
3. Microfiber cloths and lightly damp cleaning: Make sure the cloth is not too wet to avoid damaging the shelf material. Microfiber cloths often pick up hair very well when lightly brushed over the surface.
4. Pet grooming: If possible, remove loose hair before the cat sleeps on the KALLAX by regularly brushing your cat. This fundamentally reduces hair buildup in the resting area.
A side question: How often do you clean the area, and how heavy is the hair shedding typically? The optimal cleaning frequency can be better estimated depending on the amount.
Best regards and good luck with the cleaning!
rebufar
22 Apr 2021 19:13
Palenar schrieb:
If possible, remove loose hair from the KALLAX before sleeping by regularly brushing your male cat.
Sorry, but that sounds a bit too focused on the pet – the core issue is really the design of the furniture piece! Let’s be honest: you’ve created a sleeping spot for your pet that basically acts as a dust and hair trap. That contradicts itself.
Maybe it would be better to consider why the animal chooses to sleep there – is it because of cold or comfort? Then you could simply place a washable blanket or mat inside, which is much easier to clean than constantly wiping away hair.
So instead of always relying on the usual cleaning methods, a smarter approach would be to systematically reduce the cause of hair buildup – for example, by combining adjustments to the sleeping area with regular grooming.
You could also say the mistake lies in the concept: why turn a shelving unit into a bed when simple measures can prevent such issues?
Jamalli
23 Apr 2021 07:29
rebufar schrieb:
Why turn a shelf into a bed when such consequences can be caused by simple means?
I would like to make a more nuanced point here. Of course, the KALLAX shelf is not primarily designed as a pet bed, but that is exactly what makes the challenge interesting: How can everyday objects be adapted for pet use without causing ongoing problems?
Your argument suggests that the cause lies only with the piece of furniture. However, the question should also consider whether the pet (a tomcat in your case) chooses to sleep there voluntarily because certain needs are being met (privacy, proximity to humans, warmth).
Therefore, the solution might actually involve combining furniture design, pet behavior, and care—so instead of just criticizing the furniture, a practical approach using various aids (as Palenar described) might be more effective.
One approach could be to equip the shelf with a removable, washable mat that sticks to the edges or is attached with Velcro. This way, the issue with pet hair can be better managed without damaging the core material of the furniture.
For more sustainable cleaning, using materials with electrostatic properties also makes sense—this is where special microfiber cloths or rollers based on electrostatic hair removal could play an important role.
So: would it be helpful to share more information about your cleaning routine and your cat’s exact sleeping habits to make more tailored suggestions?
