ᐅ My KALLAX shelf rattles at higher volumes – should I tighten it?
Created on: 22 May 2020 18:23
ilian
ilian
22 May 2020 18:23
I have a KALLAX shelf from Ikea that starts to rattle slightly at higher volumes, for example when I play music very loudly through my speakers. The noises seem to come from the connections between the shelves and the side panels – probably small movements in the wood or the screws.
I’m wondering: Does it make sense to tighten the screws or connections of the KALLAX shelf to reduce this rattling?
At the same time, I don’t want to overdo it and risk damaging the wood or making the shelf unstable. Has anyone had experience with this? Is there a recommendation on how tight the screws should be without compromising the structure? Maybe there are other causes I should consider?
Thanks in advance for your advice!
TANNAU
22 May 2020 18:57
ilian schrieb:
I am wondering now: Does it make sense to tighten the screws or connections of the KALLAX shelf to reduce this rattling?
Yes, you should do that. Screws tend to loosen due to vibrations and use, so tightening them usually helps. Don’t overtighten, though, as you might crush the wood.
kauti
22 May 2020 21:12
ilian schrieb:
The rattling seems to come from the connections between the shelves and the side panels
This is typical for KALLAX shelves, as this furniture is usually constructed quite loosely with dowels and screws to make assembly and disassembly easier. Gently tightening the screws can improve rigidity and reduce vibrations without damaging the wood, as long as you are careful with the torque.
Additionally, I recommend checking that the wooden dowels fit securely, since a slightly misaligned position can also cause rattling noises.
If that’s not enough, sometimes attaching felt or foam rubber strips at the contact points helps to dampen minor gaps. It’s also important to place the shelf on a level surface to minimize unwanted stresses.
BAUEVA
23 May 2020 08:44
ilian schrieb:
Does anyone have experience with this? Is there a recommendation on how tightly the screws should be fastened without compromising the structure?
Retightening the screws seems like the most obvious solution, but it’s important to consider whether the rattling is actually caused by loose screws. The KALLAX series is known not to be completely rigid since the particleboard with melamine resin coating can vibrate noticeably at high volumes.
I would suggest asking whether it might be more effective to first identify the source of the vibration. Are there specific frequencies from your speakers causing it? Is the shelf possibly not resting fully stable on the floor?
Without a more detailed analysis, there is a risk of only addressing the symptoms rather than the root cause. Tightening the screws too much could stress the particleboard and potentially cause cracks.
Therefore, my recommendation is to retighten the screws moderately—ideally with plastic washers between the screw heads and the wood to avoid pressure marks. At the same time, check the shelf’s base and, if necessary, use anti-slip mats.
Please feel free to share more details about the exact construction and placement of the shelf in the thread for more targeted advice.
