ᐅ My Kallax unit in the bathroom constantly feels damp – are there protective coatings available?
Created on: 8 Aug 2024 07:52
Meola
Meola
8 Aug 2024 07:52
I have a problem with my Kallax shelf that I keep in the bathroom. Since the bathroom is very humid, the shelf remains constantly damp, which worries me about possible mold or permanent swelling of the wood.
My question: Are there special protective coatings or sealants that can be applied to the Kallax to reliably protect it from moisture without negatively affecting its appearance?
I have a gray Kallax, so more of a laminated version, in case that matters. Do protective coatings even work on laminate? And if yes, do you have any product recommendations or personal experiences?
Thanks in advance for your advice!
P.S. If it’s relevant: The shelf is not directly next to a shower but is in a steam-bath-like environment with high humidity every day.
Elijah42
8 Aug 2024 08:16
You could simply apply a clear varnish, preferably one designed for damp rooms.
Make sure that the varnish also adheres well to plastics or laminated surfaces.
Alternatively, liquid rubber coating is also a good option.
Nabla64
8 Aug 2024 10:43
Hello Meola,
I want to provide a brief guide on how to protect a Kallax unit in a bathroom, including an explanation of why it may or may not hold up.
1. First: The white or gray Kallax is usually coated with a melamine foil. While this coating is water-resistant, it is not 100% moisture-proof. Prolonged high humidity can damage the edges.
2. To better protect the shelf, you should additionally seal the edges and possibly the surfaces. Special clear coats or polyurethane (PU) varnishes are suitable for this. These coatings are impact- and moisture-resistant.
3. It’s best to choose a water-based varnish that is suitable for coated surfaces. Ideally, test it first on an inconspicuous spot to see if the varnish affects the foil.
4. Apply the varnish in thin, even layers, one after another. Light sanding between coats improves adhesion.
5. Alternatively, there are spray protective varnishes that dry quickly.
One common mistake I often see: some people only treat the outer surfaces but forget the edges. The edges especially absorb moisture and swell quickly.
Summary: Yes, protective varnishes are available and they help. Water-based clear PU varnishes are usually the best choice, but always test first, especially with melamine-coated surfaces.
Hope this helps you!
warrenka57
8 Aug 2024 13:25
Nabla64 schrieb:
It's best to choose a water-based paint suitable for coated surfaces.
That definitely sounds professional, thanks for that! I have a similar issue with moisture in my bathroom, and I find it annoying when the furniture constantly feels damp. It really worries me because I don’t want the piece to get damaged.
Maybe I should try using a protective varnish like that too, even though I’m unsure if I can apply it evenly.
Does anyone have tips on how to paint as straight and bubble-free as possible? I’m not a professional at this and I’m afraid of causing more damage than protection.
TEOZAR
8 Aug 2024 14:47
Hello Meola and everyone,
I’m happy to explain in more detail because the topic of moisture and Kallax in the bathroom is quite complex.
The standard version of Kallax is made from wood particleboard with a melamine surface. The surface is slightly water-resistant but does not completely prevent moisture from seeping into the edges of the wood. It is precisely there that the wood swells and becomes slimy or moldy if the humidity is constantly high.
Protective coatings you can apply are usually PU-based clear varnishes or special water-repellent sealants designed for furniture in damp rooms. Important steps are:
- First, clean and degrease the surface.
- Lightly sand the surface, especially the edges, to improve adhesion.
- Choose a varnish suitable for coated surfaces (it’s a good idea to test on an inconspicuous spot first).
- Apply several thin layers and allow them to dry well.
If you want to be extra safe, there are also furniture options specifically designed for bathrooms that are manufactured to be water-resistant from the start—however, this is obviously not a solution for an existing Kallax.
Regarding steam baths: almost any furniture is not ideal for that. Even with varnish, continuous daily exposure to steam is critical.
I hope this clarifies the options. Feel free to ask if you have any questions!
lisku
9 Aug 2024 09:12
Meola schrieb:
Do protective coatings work on film at all?
Yes, but the adhesion is limited because the film surface is often very smooth. Light sanding improves the adhesion.
TEOZAR schrieb:
Apply several thin layers.
Exactly, thick layers can crack or cause bubbles. Better to apply thin layers multiple times.
I have had good results with a furniture-grade polyurethane varnish, applied with a fine foam roller. Not a brush, as that leaves streaks.
