ᐅ My KALLAX unit is difficult to clean after moving—any tips?
Created on: 8 Apr 2015 10:23
lyanron
I recently moved my KALLAX and unfortunately noticed that cleaning it has become much more difficult. During the move, dust and dirt likely settled into the gaps and corners that were previously easier to access. Since the furniture has some sealed or firmly glued joints, simple cleaning methods don’t work very well.
My question is: What tricks or cleaning products do you use to thoroughly clean the KALLAX after a move while still being gentle on the material? I want to avoid damaging the surface or compromising its stability. Has anyone had experience with hard-to-reach crevices or can offer tips on how to best care for the wood or coating?
I’m really looking forward to your advice!
tu-se60
8 Apr 2015 14:38
Compressed air sprays are good for blowing out dust.
Avoid moisture beforehand.
Use a vacuum cleaner to suck up dust before wiping.
Guyju
9 Apr 2015 09:22
Hello lyanron,
here is a simple step-by-step guide that has worked well for me:
1. Disassemble furniture if possible to access all surfaces easily.
2. Remove loose dirt first with a vacuum cleaner.
3. Prepare a cleaning solution using lukewarm water and a mild dish soap.
4. Dip a soft toothbrush into the solution and gently scrub the gaps and joints.
5. Wipe afterwards with a clean, slightly damp microfiber cloth.
6. Dry the surface with a dry cloth to prevent water spots.
Important: Avoid abrasive cleaners or harsh chemicals that can dull the finish or damage the paint.
If you have tougher dirt, you can add a small amount of vinegar essence to the water, but use it very carefully and rinse thoroughly afterwards.
Good luck!
praWarre69
9 Apr 2015 11:10
I know the problem – moving usually makes everything a bit more complicated. 🙂
I’ve also worked with a long-bristled brush like that, which was really handy for getting into corners without touching the furniture.
And what worked great for me: a slightly damp cloth with some furniture oil. It preserves the surface at the same time and makes it look almost like new afterwards.
Give it a try, it adds a nice finish as well. 🙂
Morgan
9 Apr 2015 11:58
lyanron schrieb:
I’ll give the toothbrush a try, that sounds good. Do you use any special cleaning agent or just water?
I usually just use a little dish soap mixed with water. That’s enough to prevent scratches and loosen dirt. Depending on how dirty it is, you can also try diluting a splash of vinegar, but be careful with the surface.
The water should only be damp, never wet, especially around the edges to prevent the wood from swelling.
sarpa
10 Apr 2015 08:36
Guyju schrieb:
Avoid abrasive cleaners or harsh chemicals that can dull the surface or damage the finish.
This is an important point.
Additionally, I recommend paying attention to temperature variations when cleaning after moving in: using water that is too cold or exposing the surfaces to direct sunlight during or immediately after cleaning can weaken the connectors.
In summary: thoroughness is important, but it should be done carefully to preserve both stability and appearance.
