ᐅ My Kallax unit warped after being moved—should I try to realign it?
Created on: 26 Jun 2023 20:37
BenfarHello everyone,
I recently reorganized my Kallax shelving unit to make better use of the storage space. While doing so, I noticed that the shelf seems to have warped slightly – one of the sides is no longer completely straight and looks a bit crooked. My question is: Is it advisable to realign the shelf, and if so, what is the best way to do this without causing any damage?
The parts are assembled by fitting together, so I suspect some tension built up during the rearrangement. Has anyone had experience with this? I prefer not to use force, but I’m not happy with how it looks in this condition.
Thanks in advance for any advice!
Benfar schrieb:
I recently rearranged my Kallax shelf, and it warped during the process.Hello Benfar,
This actually happens quite often, especially if the shelf is heavily loaded or placed at an angle while rearranging. Although the Kallax is sturdy, its modular system can allow the connections to loosen or shift slightly.
My advice: First, try to carefully straighten the shelf step by step. Place it on the most level surface possible and check with a spirit level whether the sides are vertical. If the parts feel a bit loose, you can gently press the connectors back together. However, avoid applying excessive force to prevent damaging the joints.
If you place heavy items on the shelf, try to distribute the weight evenly. This helps to avoid further warping.
If you are not experienced with tools or disassembly, it’s better to proceed more gently. It is also normal for wood-based materials to expand or contract slightly due to changes in temperature and humidity.
I hope this helps you!
I completely understand why that would bother you—especially when you feel like you’ve done everything correctly.
I would suggest trying gently, but if you notice it doesn’t fit properly or the material creaks or feels warped, it’s better not to force it too much. In my experience, the wood sometimes relaxes again after a few days, especially if it’s kept in a room with a stable temperature.
Stay calm and don’t stress about it; everyone manages these things step by step.
gregto schrieb:
The shelf can warp from weight and surface pressure; occasionally pressing it firmly helps.
Benfar schrieb:
Is it advisable to realign the shelf?Yes, realigning is advisable.
Place the shelf upright on a level surface. Press any shifted joints back into place. Avoid excessive tilting or pulling.
This will help prevent damage.
Benfar schrieb:
Is it advisable to realign the shelf, and if so, how can it be done without causing damage?I wonder if the warping might also indicate a structural issue. Are you sure that the base plate or the floor beneath it is completely level? An uneven surface can exaggerate or even cause the appearance of warping.
Also, how exactly did you reposition the shelf? Was it slid sideways or lifted up?
It would be sensible to first align the outer frame precisely on a flat surface, possibly secure it temporarily with clamps, and check whether the problem reoccurs under load or after some time.
My suggestion: The shelf is modular but essentially a clip-together system without screw-fastened braces. Its stability is limited. Repeated warping can eventually fatigue the material and cause spiral-shaped distortions.
Therefore, I would mainly examine the surrounding conditions and carefully observe how the shelf responds to stress.
kasan schrieb:
Are you sure that the base plate or the floor underneath is completely level?Thanks, kasan, I hadn’t considered that during the initial alignment. Actually, the shelf is now standing on a relatively new laminate floor – that should be level, but I will check again with a spirit level.
JAFUHAU schrieb:
The wood sometimes relaxes again after a few daysThat’s reassuring; I’ll give it a few more days before applying too much force.
If the shelf doesn’t settle on its own: Are there any recommended tools or aids to securely press the joints together without using excessive force?
