Hello dear house building community,
A brief introduction about me:
I am 17 years old and believe that you can never start early enough when it comes to house construction. For about half a year now, I have slowly started to explore the topic of building a house. Since you are experts in this field, I wanted to first ask which reading materials you would recommend.
The actual question:
I already have some ideas about how my house should look. I want my house to have a beautiful Mediterranean style, and I found the following images of my preferred type of stone on Google:
In this image, I am interested in the slightly yellow stone type used on the house (to the left and right of the white column).
Alternatively, also the stone type of the house above 🙂
I hope you understand the style I associate with my house:
It should be built with a yellowish Mediterranean-type stone. My idea would be sandstone, but I wanted to ask you about this. Thank you very much in advance for your help.
Kind regards
ME 🙂
Kind regards
ME 🙂
DasBauProjekt schrieb:
So, my question:
What is the type of stone used in the houses? I want to inquire further in that direction 🙂 Hello!
This "type of stone" is actually called FACADE PAINT! Behind that is plaster, and no one will be able to tell you anything about the stone beneath the plaster.
TomTom1.
I had to read it several times as well: houses can be built using many different construction methods. Concrete, aerated concrete blocks, bricks, foam shells filled with concrete, and so on. The house is then covered with a layer of plaster. In Italy, this is often a lime plaster that is smoothed, while in Germany it is usually a sprayed plaster.
Regarding the pictures: these are beautiful buildings, but I’m afraid it takes several years of saving to afford such a construction. Or you need to find a building plot where this kind of house is allowed. Friends of ours recently gave up on their dream of a Tuscan-style house because there are no building plots here where that is permitted. Too many regulations.
But it is good to have a goal in mind as a young person.
DasBauProjekt23 Mar 2012 20:05First of all, thank you very much 🙂 I admit, the question was a bit poorly phrased.
Since I’m Italian, I plan to move to Italy or Spain eventually xD
I will then look into the construction of walls, plastering, and so on 🙂
One more question:
Can you recommend one or more books or resources?
One more question:
