ᐅ The Malm bed continues to squeak even after tightening the screws – how can I fix this?
Created on: 13 Jun 2022 18:42
kumefe
kumefe
13 Jun 2022 18:42
I have a Malm bed from Ikea that has been creaking for some time now, even though all the screws are tightened properly. I have already checked all the screws and connections underneath and tightened them as much as possible with the right tools, but the creaking still persists. It seems to me that the noise is coming directly from the slatted frame or the bed frame itself. Before I try applying lubricants to all the wooden parts (which might also cause damage), I wanted to ask: How can I effectively stop the creaking on a Malm bed if simply tightening the screws doesn’t help? What causes could be responsible for the noise despite firmly secured screws, and what practical steps can best resolve it? I look forward to any helpful tips and experiences you might share.
sarlo
13 Jun 2022 19:07
Hello kumefe,
First of all, thanks for your very clearly phrased question; it makes identifying the problem much easier. Unfortunately, the Malm bed is known for sometimes making noises even when the screws are tight – this often results from several factors.
The squeaking can come not only from loose screws but also from friction points between wood and metal or between wooden parts such as the slat support and the frame. Here are some tips that might help you:
1. Check if the slatted bases are seated correctly and not wobbling within the frame. If they are, sometimes small felt or foam strips placed between the slatted base and the frame can help reduce friction.
2. Tightening the screws is important, but also consider the quality and fit of the screws in the wood – if the screws have loosened slightly inside the wood, they no longer provide enough tension. You could try repairing the holes with wood glue and wooden dowels before screwing them back in.
3. Applying a dry lubricant to the contact points, such as dry Teflon spray or wax (candle wax or furniture wax), can help reduce squeaky friction points. I would avoid mineral oil or grease, as these attract dust and could make the problem worse.
4. Also check all metal elements, if any, since they can also cause noise.
If you can provide more details about the year of manufacture or the exact construction, I’d be happy to offer more specific advice.
Good luck stopping the squeaking! 🙂
kulau
14 Jun 2022 08:33
Hello kumefe,
I would like to go into more detail since I own a Malm bed myself and had similar issues.
sarlo schrieb:
The squeaking can come not only from loose screws but also from friction points between wood and metal or between wooden parts like the slatted frame supports and the frame.
That is absolutely correct. Especially the connection points between the frame parts, which are made of solid wood, tend to have slight movements under load that cause these annoying squeaking noises. Here is my approach, which was very helpful in my case:
Step 1: Pinpoint the squeak
Carefully place the bed on its side, loosen the screws only on one corner, and move the parts to listen closely to where the squeaking occurs. Often it helps to have a second person apply pressure to one corner while you gently twist the fastening points.
Step 2: Check screws with the right tools
Sometimes screws are slightly misaligned during assembly, causing too much or uneven pressure. Remove the screws one by one, inspect the threads for damage, and reinsert them using appropriate wood glue (well drying) to improve grip in the wood.
Step 3: Minimize friction points
If problem areas remain, you can apply padding materials. Felt strips or thin rubber pads work well between the frame and the slatted frame supports.
Step 4: Use dry lubricants
As mentioned, avoid oil. Instead, I recommend applying a PTFE spray to all contact surfaces. This significantly reduces friction.
Step 5: Try alternative slatted frame positions
Some Malm beds are structurally identical but offer several mounting options for the slatted frame. Sometimes shifting these can solve the problem.
As you can see, eliminating squeaking usually requires some patience with the right process. If you can provide more details about your slatted frame model, we can go into further detail.
I hope this helps you!
gekira
15 Jun 2022 12:21
To add my input:
The issue with bed frames made of particleboard with melamine coating, like the Malm type, is that the threaded inserts are usually metal and can slightly loosen from the board under load, even if the screws are tightened properly. This often causes small movements on a micrometer scale, perceived as squeaking.
Facts and measures:
- If squeaking occurs frequently, it helps to remove the screws and check the particleboard for swelling or softening.
- It may be necessary to fill the old screw holes with wooden dowels or glue combined with small wooden pieces to improve the hold.
- Applying a graphite lubricant or dry PTFE lubricant to the contact surfaces of the wooden parts can significantly reduce friction without damaging the material structure.
- Fluctuations in humidity can cause the wood elements to slightly expand and contract, leading to temporary noises. Therefore, ambient humidity is an important factor to consider.
- Metal threaded inserts can be secured with a small drop of medium-strength threadlocker to prevent movement.
In summary: A permanent solution usually requires a combination of mechanical repair of the screw mounts and reducing friction points.
Simply re-tightening the screws is generally only a temporary measure.
I hope these facts help you solve the problem.
