ᐅ Make the water line from the rainwater cistern frost-proof
Created on: 23 Oct 2019 07:01
Changeling
Changeling
23 Oct 2019 07:01
I have a cistern with a pump that I used to water my garden during the summer. Since there wasn’t enough time in spring before moving in (and also because the final position of the outlet wasn’t decided yet), I simply connected a garden hose to the pump, which now runs above ground to the outlet (spigot). Here is a sketch:
Sketch of a house with green piping, red radiator, and ground line.
My question: How can I make this frost-proof? My idea was to install some kind of valve at the blue circle, which I would open in winter to drain all the water from the hose back into the cistern. The pump would of course be turned off (I don’t need water in winter).
Are there better solutions for this setup? How have you dealt with similar situations? I’d prefer not to completely remove the pump every winter unless it significantly extends the pump’s lifespan.
Bookstar
23 Oct 2019 08:34
I take out the pump, disconnect the hose, and the issue is resolved. Just 5 minutes of effort once a year.
Joedreck
23 Oct 2019 10:19
Should we stick with the hose?
rick201823 Oct 2019 20:27
I would connect and bury a PE-HD pressure pipe (12.5 bar) similar to a proper irrigation system.
Install a T-piece with a valve inside the cistern. In autumn, open the valve and blow through it from the other side with compressed air. Gravity alone is usually sufficient.
If you prefer to stick with the hose, add a connector inside the cistern. Detach the hose, let it drain or blow it out, and store the hose until spring.
Joedreck
23 Oct 2019 20:43
That's why I asked... I would work directly with pipes and maybe set up 2-3 tap points. Very practical.
Gartenfreund
24 Oct 2019 02:37
I would do it like this.
Lay the pipe with a slope toward the cistern.
This way, you don’t need to use a compressor or anything else.
Where the blue circle is marked, install a T-piece with a valve. It’s best if this points downward.
