ᐅ Looking for a wireless intercom system with local power supply
Created on: 8 May 2019 12:51
hampshire
I would like to install a mailbox with a doorbell and intercom at the entrance to our property, but I really don’t want to run any cables out there. My requirements are:
  • 3 doorbell buttons
  • DECT connection for the intercom linked to the FritzBox
  • local power supply (battery + solar panel)
The distance in a straight line between the intercom and the FritzBox is about 35 m (115 feet), but the cabling route would be around 100 m (330 feet).
The second-best option would be to only run power there, moving the “doorbell mailbox” to the opposite side of the street, where it is somewhat less convenient.
Does anyone have any suggestions?
Thanks in advance!
Leo
10 May 2019 07:51
Or you can use, for example, a Doorbird D2103V (Wi-Fi).
hampshire
10 May 2019 10:41
Thanks for the Doorbird tip – that would be like using a sledgehammer to crack a nut for me – I definitely don’t need a camera or access chip. However, Wi-Fi connectivity is appealing.
rick201810 May 2019 12:14
But please test the connection first at 35 meters (115 feet) with walls in between. The 2.4 GHz network experiences a lot of interference from other wireless networks. That’s why I didn’t mention it. Besides, I wouldn’t want the doorbell and door opener connected to the cloud...
Leo
10 May 2019 13:06
I understand that the Doorbird can also operate without internet, but some functions would not be available.
hampshire
10 May 2019 21:27
It is only one wall made of wood. I prefer a different material than you, Rick.
By the way, if you want to see beautiful concrete, I recommend a visit to the Langen Foundation. The Japanese architect Ando is famous for his smooth concrete. To my knowledge, this is his only building in Europe. It is located near Neuss.
Traumfaenger
10 May 2019 22:30
hampshire schrieb:
The second-best solution would be to run only electricity there,
If that is acceptable for you, I even have a proposed solution. Look up TP Link, powerline adapters, and similar devices. They transmit the network signal over the electrical wiring. So you plug a device into a socket at one end, which you can also connect to a LAN cable. At the other end, where the electrical wiring ends, you plug the same type of adapter into the outlet, allowing you to tap the signal again via LAN cable. You get both electricity AND a network signal. These adapters are also available with Wi-Fi, but I find LAN to be better.
Apart from the fact that Wi-Fi outdoors can be even more easily intercepted than inside your apartment, the data transfer rate with LAN is simply much higher. This also makes video transmission easier (for example, a doorbell with a camera). Even without a camera, I would recommend focusing on a high data transfer rate for better voice quality. Maybe you have already experienced how well IP telephony works with a poor data connection (you can test this with Skype).
I would advise against the idea of trying to pick up the Wi-Fi signal from the house over a distance of 35 meters (115 feet). Try testing with your phone how good the signal and data transfer rate are when you are 35 meters (115 feet) away from the house... This is not a stable solution.
