ᐅ Is it necessary to have LAN cables installed in the garage?
Created on: 11 Sep 2022 11:38
FrankChiefF
FrankChief11 Sep 2022 11:38Hello
I wanted to ask what the essential use for a LAN connection in the garage would be?
Our electrician is reluctant to install a Cat cable in the garage.
He is charging twice as much as for a Cat cable inside the house (€500 in the garage) just for a Cat socket.
Why do you absolutely need LAN in the garage?
Wallboxes usually all support Wi-Fi anyway.
We are also planning to install photovoltaic panels later on.
SaniererNRW12311 Sep 2022 11:39FrankChief schrieb:
I wanted to ask what the essential reason would be for having LAN in the garage?I can’t think of any compelling reason either.R
RotorMotor11 Sep 2022 11:40I would definitely do it.
Wallbox, cameras, photovoltaic system, radio, television, ...
Wi-Fi in the garage is usually pretty terrible.
€500 is quite expensive, especially if the garage isn’t very far away.
FrankChief11 Sep 2022 11:50The garage is attached directly to the house.
Right on the other side of the living room.
Question: Would the access point in the living room provide enough Wi-Fi coverage in the garden? So that there is still sufficient Wi-Fi signal at the far end of the garden?
The garden is approximately 11 x 20 m (36 x 66 ft).
FrankChief11 Sep 2022 12:20So, should we not skip the CAT socket in the garage?
Do wallboxes necessarily need to be connected to the LAN?
