ᐅ Lock cylinder with key recognition
Created on: 9 Feb 2019 07:53
Mummy
I am looking for a way to detect if a key is left in the front door lock.
Background: My wife insists on unlocking the front door with a key and then regularly leaves it inserted from the outside. Our neighborhood is not the safest, and the car key is attached to it as well.
I want to make sure that the key is not left in the lock all night and that the home security system triggers an alarm if all the lights go out in the evening while a key is still in the lock. Does anyone have any ideas or know of a lock cylinder that can provide such a notification?
world-e
12 Feb 2019 07:37
You could also consider a different approach: requiring the key to be in a precisely defined location within a certain time frame. At my workplace, there is a box where the keys for rental and company cars are kept. The box is opened using an ID badge. Afterwards, you select the number of the key. The key fob looks like a 6.3mm (1/4 inch) audio jack plug, which allows the system to detect when a key is available. Something like this could also be built. A door sensor at the front door could start a timer when opened, as long as the key is not in the key box. After a certain amount of time, an alarm would sound. If you open the front door for a visitor, nothing happens because the key is still in the box.
Just an idea—I’m not sure how practical it would be to implement.
Mycraft12 Feb 2019 08:19
I think it’s much more complicated than just taking the key out of the lock, and that already seems to be a problem.
O
Obstlerbaum
12 Feb 2019 09:12
All easy – after the first goodnight visit with a gun held up, she will soon stop that...
Niloa
12 Feb 2019 11:18
Or should it be a keyless lock with a code or fingerprint?
11ant12 Feb 2019 15:28
world-e schrieb:
Just an idea, no clue if it’s practically feasible.
Yes, it is. I really like the idea of shifting the warning from "key is still outside" to "key is not inside."
My preferred designated spot for the key would be the lock (interior side). It would need to be monitored whether the key reaches that spot within x seconds after opening. The door would have to be shielded on the outside so that the receiver does not mistakenly detect the RFID tag as being in the desired area when it is still outside. In other words: one side of the door would need a shielding plate so that the system only registers a valid signal on the inside.
bibi80
12 Feb 2019 15:44
Really try to move away from using a key.
We have added a lever handle to our front door in addition to the standard key, similar to a car door handle.
Our children use that now.
No key can get stuck in it.
Birgit
