Hello
I have a question.
My linoleum engineered flooring is lifting over a length of 10 cm (4 inches) and a width of about 5 mm (0.2 inches) in a joint area of the substrate due to water exposure. In this joint area, the linoleum is raised about 1 mm (0.04 inches).
Is there a special adhesive I can use to reattach the damaged area and also seal the gap of approximately 1 mm (0.04 inches)?
Thank you in advance for your help.
klaubar-1
I have a question.
klaubar-1
Moisture can become a problem quickly. Especially during wet weather, moisture is often carried into the house on shoes. Therefore, the joint, which was just under 3mm (0.12 inches), was welded shut. This way, it is definitely sealed now. We don’t mind that it is now visible.
