ᐅ KfW 55, Ytong 36.5 poorly bonded, too many gaps?
Created on: 8 Dec 2016 21:03
O
Olaf Mayer
we are currently at the shell construction stage of our KFW 55 bungalow.
Since the sun was shining at a favorable angle today, we noticed several gaps in the masonry. In some areas, the sunlight shines completely through.
We then inspected the joints more closely. Hardly any joint is properly sealed. We can almost everywhere insert the blade of a pocket knife 2-4 cm (1-1.5 inches) deep.
The site manager’s comment was, "the plaster will take care of sealing that"—2 cm (0.8 inches) on the outside and 1 cm (0.4 inches) on the inside.
We deliberately chose a 36.5 cm (14.4 inches) thick block with a lambda value of 0.09. Am I correct in understanding that if the blocks are not fully bonded, the insulation value will significantly decrease? The blocks are not properly connected... neither horizontally nor vertically.
Olaf Mayer
Person malt mit Farbroller eine rote Linie auf eine helle Außenwand
Innenraum-Eckbereich aus weißen Großformat-Betonblöcken; Spalt lässt Licht durch.
Rohbauwand aus weißen Betonblöcken in einer Ecke eines unfertigen Raums mit dunklem Boden
77.willo8 Dec 2016 22:19
Yes, still air insulates heat better than stone. Additionally, the proportion of joints compared to the stone is extremely low. Various stones are hollow inside or have cavities.
Bieber0815
9 Dec 2016 06:56
We just covered this recently, https://www.hausbau-forum.de/threads/breite-stossfugen-im-Porenbeton.17817/ ...
Joint gaps should not be wider than 3 mm (0.12 inches) and do not need to be filled with mortar. Joint gaps wider than 5 mm (0.2 inches) must be sealed with appropriate mortar.
O
Olaf Mayer
9 Dec 2016 09:44
Not comparable, since we are building monolithically. In the other thread, there is also an external thermal insulation composite system (ETICS) mentioned....
But Willo has the perfect answer... I can live with that....
Steffen80
9 Dec 2016 10:20
This is normal and the same everywhere. No need to panic. It looks odd... but it is correct.
--> "Still air insulates heat better than stone"
Leser111
29 Dec 2016 08:56
Olaf Mayer schrieb:
...Am I correct in understanding that if the block is not fully glued, the insulation value decreases significantly? The blocks are not properly connected... horizontally or vertically...
This is poorly executed. Only the bed joints (horizontal) are glued. The vertical joints are tightly butted together without any gap (butt joints). That is why blocks with tongue and groove profiles are used.
It is advisable to study the manufacturers' installation guidelines.
Best regards.
Knallkörper
31 Dec 2016 09:24
I find it confusing that you can actually see through the vertical joints. So there is no interlocking there? For me, it’s more about the mechanical stability, the insulation should be fine as others have already mentioned. I would also ask to see the technical documentation for the blocks.
