ᐅ KALLAX is standing on a sloped floor – possible solutions for leveling?
Created on: 21 Sep 2018 19:03
nonje
I have a KALLAX shelf from IKEA that I want to place on a fairly uneven wooden floorboard. The floor is visibly sloped in some areas, which causes the shelf to be unstable and wobble at times. My question is: what practical solutions do you know to level the KALLAX shelf and securely position it on a severely sloped wooden floorboard? I have already considered small pads, wooden strips, or adjustable feet, but I’m unsure what will hold up firmly over time without damaging the floor or the shelf. I would be very grateful for tips and experiences regarding this specific issue with uneven wooden floorboards!
keohudson
22 Sep 2018 11:33
chen67 schrieb:
wedging small wooden shims under the feet, cut to size beforehand
This is a simple solution, but it’s worth considering whether it might cause unwanted stress on the shelf over time, especially if the Kallax is made from particleboard. Compensating for unevenness with shims can easily distort the furniture frame, which may later result in wobbling or material damage.
Instead, I would recommend measuring the floor and then installing height-adjustable furniture feet with a firm base under the shelf. The adjustability provides flexibility and prevents stress.
Of course, this option is more involved, but it’s more stable in the long run and protects both the floor and the furniture.
Far34
22 Sep 2018 14:59
Attach the furniture feet with screw threads to adjust the height. Place floor protection underneath to prevent damage. This ensures the shelf stands securely and the floor remains intact.
Ryker66
22 Sep 2018 15:52
bente schrieb:
My tip: Use small rubber buffers
This is a good idea for minor unevenness. However, rubber buffers are usually not enough for significant inclinations; in those cases, I really recommend adjustable furniture legs.
pauPierce
23 Sep 2018 09:47
to revisit the topic, I’d like to ask: What exactly is the height difference?
With a slope of less than 1 cm (0.4 inches), some solutions like wedges or rubber pads can be combined effectively. From 2 cm (0.8 inches) and above, it’s really advisable to install individually adjustable feet. You can find these at hardware stores as threaded sleeves, which can be mounted into suitable drill holes and then adjusted until the shelf is perfectly level.
Additionally, if your shelf is standing on a wooden floorboard, it can help to use an extra sturdy, flat base as an underlay—such as a thick chipboard or plywood sheet. This effectively compensates for floor slope issues over a larger area and provides a solid foundation for the Kallax.
Has anyone done this here before?
