ᐅ Loose KALLAX Screws – Is Threadlocker Recommended?
Created on: 23 Aug 2019 08:37
Salvator54
Salvator54
23 Aug 2019 08:37
Hello everyone, I have a common issue with my IKEA KALLAX shelving unit: the screws keep loosening, especially those securing the corner joints. The unit itself is stable, but when I move it or rearrange it, I notice the screws become increasingly loose in some places. So, my question is:
Is it advisable to use threadlocker (such as thread-locking adhesive or similar) to secure the screws on a KALLAX shelving unit? Or would that cause problems later, for example when disassembling or adjusting it?
Perhaps someone here has experience with whether this type of locking actually improves the lifespan and stability, or if it’s not really necessary. Thanks in advance for your advice!
nofomu
23 Aug 2019 09:11
Threadlocker can help if the screws frequently come loose. Use a medium-strength threadlocker. However, keep in mind that this will make readjustments more difficult.
klo40
23 Aug 2019 10:58
Hello, I believe this deserves a closer look:
1. Why do screws loosen? This is usually due to vibrations, movement, or wood that slightly deforms.
2. Screw locking compounds (e.g., threadlocker like Loctite) can effectively prevent screws from loosening even when there is movement.
3. The downside is that later removal becomes more difficult, sometimes requiring more force or appropriate tools.
My advice: If your shelf is located near areas with frequent use or movement (e.g., a child's room or during frequent relocations), a medium-strength threadlocker can really help. Otherwise, it’s better to avoid it, but check and lightly tighten the screws regularly if needed.
Additionally, with KALLAX, you can also check whether all screws are tightened evenly – sometimes uneven tension causes loosening.
Conclusion: Using a threadlocker is useful if you want long-term stability, but it reduces the flexibility for later adjustments.
TARAON
23 Aug 2019 12:43
Oh, I know that! My KALLAX also sometimes has loose screws – especially when you move the shelves around often, it starts to creak and wobble.
klo40 schrieb:
Threadlocker is useful if you want long-term stability, but it reduces the flexibility for later adjustments.
That sums it up pretty well. For me, a drop of threadlocker worked wonders. Still, especially for furniture made with wood fiberboard, I wouldn’t use the strongest type, or the screw holes can get damaged quickly if you want to make any changes later.
But hey, little effort, big effect – and there are even ones that can be undone again 🙂
U
umberto
23 Aug 2019 17:02
Threadlocker yes, but not the permanent type. Choose a medium strength version that you can loosen again with some effort. That will work.
Laurence
24 Aug 2019 07:29
I would like to add an important point to the discussion: The material of the KALLAX shelf is melamine-coated particleboard, which means that the screw holes are not as durable as those in solid wood.
When using threadlocker, it is important not to overtighten the screws to avoid damaging the material.
Additionally, if the furniture is frequently assembled and disassembled, threadlocker should be used sparingly. Conversely, if the shelf is assembled once and then rarely moved, using a medium-strength threadlocker is acceptable.
However, if the shelf is taken apart often, it is advisable to check the torque and, if necessary, readjust the screws without permanently gluing them.
My recommendation:
1) Tighten screws cleanly before assembly (do not overtighten)
2) Use medium-strength threadlocker on heavily loaded areas
3) Regularly check the screws after some time
This way, loosening is prevented while avoiding unnecessary problems during disassembly.
