I am currently planning to redesign my music room and want to use an IKEA Kallax shelf unit as a storage solution. However, I am concerned about possible issues with structure-borne sound and vibrations, especially low-frequency bass vibrations that could come from a subwoofer or instruments.
Can the construction of the Kallax shelf amplify vibrations or become problematic for the stability and sound quality in the room? I wonder if the shelf, due to its typical material properties (particleboard, joints), might produce resonances that could interfere with sensitive recordings or playing music.
Are there any experiences or recommendations on how to use a Kallax shelf optimally in a music room without risking negative effects from vibrations? Perhaps the shelf can be dampened or decoupled?
Thanks for any insights!
Tolusar schrieb:
Can the construction of the Kallax shelf amplify vibrations or even cause issues with stability and sound quality in the room?The Kallax is quite stable, but with strong low-frequency loads, you might notice slight resonances. If this bothers you, simply place rubber pads underneath or secure the shelf to the wall.
Hello Tolusar,
I can understand your concern well. Vibrations in the music room, especially with low-frequency bass, can be an issue since furniture often acts as a resonating body. The Kallax is made of particleboard, which is generally prone to vibrations but not highly resonant.
Those are good initial steps. Additionally, I would recommend placing heavier items carefully to minimize unnecessary vibrations. If you want to be absolutely sure, you can add insulation material behind the shelf or use special decoupling mats.
Also consider the overall room acoustics: sometimes it makes more sense to address the bass through the floor or specialized vibration absorbers rather than focusing mainly on furniture as the primary source of vibrations.
Hope this helps you a bit!
WARREN schrieb:
If it bothers you, simply place rubber pads underneath or secure the shelf to the wall.
I understand the concern about vibrations with a Kallax unit, but it might be somewhat exaggerated depending on the strength of the bass source and the sensitivity of your recording equipment.
The Kallax is definitely not designed as an acoustic element or resonator. The thin particleboard shelves aren’t known for their vibration-damping qualities, but they aren’t inherently very resonant either. However, if you’re working in a high-end recording environment, I would be cautious about placing the furniture directly next to microphones or speakers.
I consider room acoustics and proper decoupling of the sound sources from the floor to be much more important factors.
That’s a practical recommendation I agree with. In general, furniture like the Kallax does absorb some vibrations, but usually transfers less sound energy than built-in structures or poorly insulated walls.
I’d be curious if you’re referring more to a recording setup or just playing music. The requirements differ significantly.
Tolusar schrieb:
whether the shelving unit generates resonances due to common material properties that could interfere with sensitive recordings or during musical performance
WARREN schrieb:
placing rubber pads underneath or fixing the shelving to the wall
Regarding the topic of Kallax in the music room and vibrations, I can add the following:
Due to the material, Kallax is not an optimized solution for acoustic purposes. The thin particleboard panels and the box construction can slightly amplify or dampen vibrations, depending on how the shelf is filled and which frequencies are being excited where.
That sums it up well. I would recommend, especially if you work with microphones, placing the shelf on isolation material and ensuring that no devices transmit vibrations directly onto the shelf. Acoustic decoupling of the bass source (e.g., subwoofer) from the floor is often much more effective than worrying about furniture vibrations.
Additionally, compartments can be filled with sound-absorbing materials such as acoustic foam or even heavy books to minimize resonances.
My advice: test the room with and without the Kallax and listen carefully to notice any changes in sound. In practice, the shelf is usually not a problem as long as it is not misused as a diffusely reflecting surface.
If you want, I can also provide recommendations for targeted room acoustic treatments.
Tommy38 schrieb:
Kallax is made of wood particleboard, which is generally prone to vibrations but not highly resonant.
