ᐅ Kallax stored in the attic over winter – everything warped!
Created on: 22 Jul 2016 18:02
V
Vinfu
V
Vinfu
22 Jul 2016 18:02
Before winter, I stored an IKEA Kallax shelf on our unheated attic. Now that winter is over, I unfortunately noticed that the shelf has warped in several places. The individual shelves are no longer straight, the joints are loosening, and overall it looks like moisture and temperature fluctuations have taken quite a toll on the wood.
My question is: How winterproof or suitable is the material of the Kallax shelf in general for damp and cold storage areas like an attic? Are there any tips on how to store such a shelf properly to prevent warping and damage caused by moisture?
Perhaps some of you have had similar experiences or even solutions. Looking forward to your opinions!
lubla
22 Jul 2016 18:27
Kallax is not really designed for outdoor or damp areas. Particleboard absorbs moisture and swells. It is best to keep the shelving unit in well-ventilated, dry rooms. A constant issue in attics: moisture and extreme temperature fluctuations are harmful to particleboard.
LAYNE
22 Jul 2016 19:03
Oh, that sounds like the typical attic curse for furniture! 😅 Kallax thrives in stable, dry conditions, and a cold, damp attic is more like its nightmare. I had almost the same experience – some of the boards looked like they had survived a small storm.
My solution? A dehumidifier for the room and occasional ventilation.
In the meantime, could you maybe cover the shelf with a sheet or tarp? That protects against moisture, but it should be breathable to prevent mold risk.
V
Vinfu
22 Jul 2016 21:45
LAYNE schrieb:
Could you maybe cover the shelf with a sheet in the meantime? That protects against moisture, but it should be breathable to prevent mold risk.
Thanks for the tip! Using a breathable sheet sounds important; I hadn’t really thought about that before.
At the moment, I just left the shelf standing in the corner without any protection. In winter, the temperature here varies a lot between day and night, and on top of that, there’s increased humidity in the attic.
I’m also wondering if there are reliable methods to stabilize the structure of the particleboard panels again, or if the shelf is simply no longer load-bearing. Has anyone had experience with repairs or preventing further damage?
dota57
23 Jul 2016 07:38
There is little you can do to stabilize warped particleboard, as the material is usually permanently damaged by moisture.
My advice: place the shelving unit in a dry area where temperature and humidity are as constant as possible.
If possible, disassemble the shelving and check whether the individual parts are still straight and dry. Warping can sometimes be partially corrected by carefully realigning the components and storing them dry, but the load-bearing capacity will be reduced.
An alternative would be to exchange the shelving or acquire a new one and store it properly from the start.
V
Vinfu
24 Jul 2016 10:15
A quick question:
Can anyone roughly estimate how much temperature fluctuation an uninsulated attic can experience without causing significant damage to Kallax or similar furniture during winter?
I know that moisture is the biggest factor, but what about temperature alone?
My attic sometimes cools down to just under 5°C (41°F) at night and rises to 20°C (68°F) or more during the day. Is that critical? I would appreciate it if someone could help with figures or experience!
