ᐅ Kallax Hinge Broken – Where to Find a Replacement?
Created on: 7 Sep 2024 09:27
Sinus4
Sinus4
7 Sep 2024 09:27
Hello everyone, I just noticed that one of the hinges on the door frame of my Ikea Kallax shelf has broken. The hinge is obviously made of plastic, did not withstand several load cycles, and is now giving way. My question is for anyone who has already sourced replacements for such Kallax hinges: Where can you get original replacement hinges that are definitely compatible? I would prefer not to use generic parts, as the dimensions and manufacturing quality are often critical with these special hinges. Are there direct IKEA replacement parts or recommended suppliers online? Any advice on whether similar hinges from other manufacturers fit without issues would also be helpful. Thanks in advance!
nolan
7 Sep 2024 10:34
Hello Sinus4, the best option is to order replacement parts directly from IKEA. IKEA offers an online replacement parts service where you can usually find Kallax hinges under the correct article number. Alternatively, you can also ask for help at an IKEA store.
PeoDaniel
7 Sep 2024 12:08
Hello Sinus4,
I completely understand your concern, as not every hinge fits exactly, and load capacity is especially important. Ikea does offer spare parts in their stores, and you can also request replacement parts online via their website or by phone. I always recommend contacting Ikea first, as they know best which hinges fit the specific model.
If that doesn’t work or you can’t get the original parts, hinges from specialist furniture hardware suppliers, such as Lamello or Hettich, are a good option. You can search based on dimensions and mounting type. The drilling distances and opening angle are important specifications. Sometimes Ikea hinges can be replaced with these alternatives – however, these are often made of metal and the operation may feel different.
If you’d like, feel free to share your exact measurements or the Ikea model number here; then we can look for compatible alternatives together 🙂
fredle
8 Sep 2024 07:53
Hello Sinus4,
I’m happy to support PeoDaniel here with some practical tips. If the hinge on your Kallax has broken, it’s best to first find the exact IKEA part number for the hinge – you can enter this on IKEA’s spare parts page or look it up in the catalog.
In practice, with Kallax units, the usual approach is:
1. Order original replacement parts from IKEA – they fit perfectly.
2. If IKEA no longer has the parts, there are several online stores specializing in furniture fittings that offer compatible hinges with precise measurements. Important factors are the drilling distances, hinge type (e.g., 35mm cup mount), and opening angle (usually 110° or 165° for Kallax fronts).
3. Always check the measurements carefully and compare them to the installed hinge before purchasing!
A common mistake is buying hinges with the wrong opening range or drill pattern, which can cause installation issues and improper stress on the parts.
If you want, I can send you a brief guide on how to measure the hinge accurately.
PeoDaniel schrieb:
I always recommend contacting IKEA first
That sums it up perfectly. Good luck, and feel free to ask if you need any more help!
