ᐅ KALLAX doors keep falling off because of drafts – would a magnetic solution help?
Created on: 5 Feb 2023 09:17
Raimund
Raimund
5 Feb 2023 09:17
I have been dealing with an annoying issue for some time now with my KALLAX shelves from IKEA. The doors that I mounted on the KALLAX units keep falling off whenever there is a draft through the windows or doors in the room. This means that the airflow is apparently strong enough to dislodge the doors from the clips or hinges.
My question to you is: Does anyone have experience with a permanent and secure solution to prevent KALLAX doors from falling off due to drafts? I am especially interested in whether installing magnets on the door and the frame is a practical method. Are there any important points to consider, such as the exact placement of the magnets or the best type of magnets to use?
I would really appreciate any tips, experiences, or alternative solutions if the magnet solution is not ideal. Thanks in advance!
KINMIN4
5 Feb 2023 09:43
The magnet solution works well. Simply attach strong neodymium magnets to the inside of the door and to the shelf. Important: Ensure the same polarity, otherwise they will attract each other. This keeps the door securely in place.
GLALEO
5 Feb 2023 12:26
KINMIN4 schrieb:
Magnet solution is good.
Great tip! 🙂
I had exactly the same problem with my KALLAX doors and solved it using small strong magnets that I bought cheaply online. Since then, nothing gets stuck or falls out – it’s really brilliant!
A small addition: I placed them flush on the top edge, so they hold perfectly and look almost invisible. Definitely give it a try; it’s so satisfying when that annoying problem is finally gone!!!
kaubi
5 Feb 2023 15:58
I have thoroughly studied this topic and can offer the following technical recommendations:
The challenge with KALLAX doors is that they are usually mounted only on simple hinges and lack fixed locking points, which can cause them to pop open quickly due to drafts. The magnetic solution is generally effective, but the following points should be considered:
1. Magnet selection: Neodymium magnets are ideal because of their strong holding force relative to their small size. However, the holding force should be chosen so that the doors can still be opened easily.
2. Positioning: The optimal setup uses two magnets per door—one at the top and one at the bottom—aligned with metal counterparts inside the cabinet. To balance the air pressure, the force should be evenly distributed to prevent warping.
3. Installation notes: Magnets and counterpart plates (e.g., flat steel strips) should be mounted flush, either glued or screwed in, so nothing protrudes and the doors close neatly.
4. Alternatives: If the magnetic force is insufficient, small latches or catches can be added as supplementary fasteners.
A question for you: Are your doors the standard KALLAX series, like the sliding door model, or are they modified doors with separate hinges? The solution may vary depending on the construction.
If you wish, I can also provide a list of sources and recommended magnet sizes.
Raimund
5 Feb 2023 18:03
kaubi schrieb:
A quick question for you: Are your doors the simple KALLAX series ones, meaning the sliding door-like model, or are they repurposed doors with separate hinges?
Thank you for the detailed answer! My doors are the original KALLAX doors with built-in hinges, so they are not sliding doors. The doors hang on two metal hinges on the side of the carcass, but they are quite loose, which makes them prone to falling out.
Using magnets at the top and bottom really sounds like a good idea. I was wondering if it might be enough to attach a magnet only at the top, but presumably the door would then catch at one point and could bend, right?
A list of recommended magnet sizes would be very helpful! How large should a magnet be at minimum to hold properly, but still allow the door to open without too much effort?
TRADI
6 Feb 2023 08:12
Regarding the magnetic solution for KALLAX doors, I can add the following:
For my own KALLAX shelf, I also used strong neodymium magnets (about 10x3mm, holding force around 2 kg [4.4 lbs]) at the time. I attached them to the upper corners on the inside of the doors and to the corresponding spots on the cabinet frame. This way, the door is securely closed but still easy to open.
It is important to tighten the hinges slightly and, if needed, improve the door’s fit within the cabinet using small foam pads or felt tape. This helps prevent wobbling, which can otherwise increase the risk of the door popping off.
One more tip: if you experience strong drafts, you might also consider combining magnets with small snap locks. These snap locks, available at hardware stores specifically for furniture, hold the door even more securely.
Magnetic solutions are definitely practical because they are visually unobtrusive and do not require visible locking mechanisms.
