ᐅ KALLAX Back Panel Splinters When Nailing – How to Prevent It?
Created on: 19 Jan 2015 08:42
barpanayot
I am currently facing the problem that the back panel of my IKEA KALLAX shelves splinters and cracks when nailing it in. I am using the original back panels, which are quite thin and made of particleboard, and I want to avoid completely damaging the back panel. Has anyone had experience with this and can offer tips on how to nail it without causing the panel to break or splinter? Are there specific nails or techniques that have proven effective in maintaining stability?
I appreciate any constructive advice!
barpanayot20 Jan 2015 07:32ixlu1 schrieb:
Sometimes it helps to apply a little wax to the nailGreat tip! I hadn’t really considered wax before; it could definitely make driving nails easier. Has anyone been using this method for a while and can confirm that it really prevents splitting?
Also, what nail thickness would you specifically recommend? I have 1.2mm and 1.6mm nails available. Which would be better in your experience for 3mm (1/8 inch) particleboard back panels?
I recommend using 1.2mm (0.05 inch) nails – they are thin enough not to put too much stress on the material. Pre-drilling is essential, preferably with a drill bit that is about 70-80% of the nail diameter. This prevents the material from splitting while still ensuring the nails hold well.
NOELIAGA schrieb:
Pre-drilling is mandatoryI totally agree. I would add: don’t spin the drill too fast to avoid roughening the wood fibers too much. And tap the nails in with gentle pressure, better multiple light taps than one hard hit.
I would like to add from my experience that it is also very helpful to protect the back panel with an underlay. For example, before nailing, place a thin board or a felt mat under it to distribute the pressure and stabilize the wood.
Also, if the shelf is going to be adjusted or taken apart later, I recommend using tape or assembly adhesive with low foam formation instead of nails.
However, if you want the shelf to be really sturdy, using 1.2 mm (0.05 inch) nails, pre-drilled, coated with wax, and carefully tapped in gives you the best chance of a splinter-free back panel.
