I am currently considering whether the IKEA KALLAX shelving unit can actually be used as a windowsill or even as a sideboard—especially regarding its load-bearing capacity and stability. Specifically: Can the KALLAX shelf support the weight of decorative items, plants, or even some heavier books over a longer period if used as a windowsill?
My main concern is the load capacity of the surface, since the shelf is not originally designed to carry most of the weight on the top panel. Has anyone had experience with whether the wood or particleboard underneath can withstand the weight without damage or sagging?
How robust is it overall when using the KALLAX as a seating option or storage surface? Thanks in advance for your insights—I would appreciate any tips and personal experiences!
Dibopeo schrieb:
Can the KALLAX shelf hold the weight of decorative items, plants, or even some thicker books over a longer period when used as a windowsill?Basically, the KALLAX shelf is made from relatively thin particleboard and is not designed as a load-bearing surface for heavy weights. For light decorations or plant pots, the shelves are usually stable enough, but you should be cautious with weights approaching several kilograms (a few pounds) per shelf.
For use as a windowsill: If the shelf is fully supported underneath and not hanging freely, it can distribute the load better. However, if it is only fixed to the wall or used as a sideboard with uneven weight distribution, I recommend reinforcing it with additional boards or metal brackets to prevent sagging.
In short: Without extra reinforcement, the load capacity for heavier items is limited, but light use is generally no problem.
JONSON schrieb:
For light decorations or flowerpots, the shelves are usually stable enoughThanks for this assessment – I had also considered using the KALLAX as a windowsill but was unsure because I prefer to place somewhat heavier plants.
I myself have repurposed my KALLAX as a sideboard and notice similar issues: with light loads everything is fine, but when I put too much weight on it or move things around often, it shows slight bending. You can almost feel the material reaching its limits.
In my experience, moisture from watering can quickly become a problem if there are no saucers under the plants. In that case, the shelf is unfortunately very vulnerable.
Dibopeo schrieb:
Can the KALLAX be used as a windowsill or sideboard?I really like the idea of using a KALLAX as a windowsill – it’s practical and often looks quite stylish 🙂
However, I agree with the previous comments that the material shouldn’t be overstressed. I would definitely recommend placing plants only on saucers to prevent water damage, and also be careful not to leave excessively heavy items on it permanently.
It’s also important to set up the shelf securely – if it wobbles or tends to tip, that’s a sign that the supporting structure isn’t ideal.
In my experience, occasionally tightening screws and even adding a thin wooden board as reinforcement on top can work wonders. Sometimes a bit of DIY effort is needed to keep everything stable ;-)
Dibopeo schrieb:
Can the KALLAX shelf hold the weight of decorative items, plants, or even a few heavier books over a longer period when used as a windowsill?Hello Dibopeo,
I have been using my KALLAX as a windowsill in the kitchen for several months. The load mainly consists of multiple plant pots, cookbooks, and a few electronic devices like a kitchen scale and a coffee grinder. So far, I haven’t noticed any visible damage.
However, I recommend ensuring that the shelf is fully supported—ideally placed on the floor—so that the weight is not only carried by the sides. The surface has a lacquer coating that offers some protection, but I still avoid letting water sit on the plant trays.
If you expect heavier loads on your windowsill, consider using additional cross braces or wooden boards for reinforcement. This helps distribute the weight better and keeps the structure durable over time.
Hope this helps you with your decision!
