I recently repurposed a Kallax shelving unit from Ikea as a pantry to organize food and supplies. However, I am now facing an issue with moisture stains appearing on the bottom shelves. Especially on the lower boards, there are dark, sometimes slightly damp spots, even though the stored items are dry and no water or other liquids have leaked.
My question is: Has anyone experienced something similar? Can the Kallax material develop such stains from rising damp or condensation? More importantly, how can I remove and prevent these moisture stains to avoid long-term damage to my pantry?
I am using the shelf in a kitchen with normal humidity (not particularly damp), placed directly on the floor. Would placing an underlay help?
Thanks for your tips and suggestions!
Kallax is made of chipboard-like material with a painted surface that is sensitive to moisture, especially at the edges and exposed cut areas.
Moisture stains usually occur due to capillary moisture absorption from the floor or condensation, particularly when the shelf is placed directly on a cold or damp surface.
For prevention, I recommend:
- Using moisture barriers or pads made of plastic or rubber between the floor and the shelf
- Avoid storing damp items on the shelf
- Leave space underneath for better air circulation
To remove moisture stains:
- Allow the shelf to dry
- Lightly sand the edges of the stains with fine sandpaper
- Treat afterwards with furniture wax or varnish
Permanently avoiding moisture is the best approach.
pikin schrieb:
Moisture stains usually occur due to capillary absorption of moisture from the ground or condensation.I experienced the same when I had my Kallax shelf in the basement. The stains were initially barely noticeable, but over time you could clearly see how the moisture was drawn upward.
What helped me back then was placing the shelf on small wooden blocks and regularly ensuring air circulation. This might also help prevent mold in case it does get too damp.
Hello Kerwin,
I have been using my Kallax as a pantry in the kitchen for several years, and I have experienced similar moisture stains. It is important to know that Kallax is made of lacquered particleboard, which does not tolerate moisture well because it can swell.
To prevent this, I can recommend the following steps:
1. Do not place the shelf directly on the floor; instead, use small feet or spacers made of plastic or wood.
2. Place a polyethylene (PE) sheet or a water-resistant mat under the shelf.
3. Ensure good ventilation – ideally in a cool, dry room or at least with some space between the shelf and the wall.
If stains are already visible, you can carefully sand the area with fine to medium grit sandpaper. Afterward, it is advisable to apply a furniture or parquet varnish to seal the material again.
These measures have helped me and are in line with recommended practices for particleboard furniture in humid environments. If the kitchen is very humid, using a dehumidifier could also be an option.
Julien schrieb:
Do not place the shelf directly on the floor; instead, use small feet or spacers made of plastic or wood. That sounds reasonable, thanks!
How useful is it to additionally protect the Kallax shelf in the kitchen with a dehumidifier? The indoor air quality is generally within the normal range (around 50-60% humidity), but maybe small amounts of condensation still settle exactly where the wood is?
JONKO schrieb:
Place the shelf on small wooden blocks and regularly ensure air circulation I will definitely try that. Could something like a narrow wooden frame all around also work, basically as a platform?
Are there any experiences with whether special furniture treatments help or rather damage the surface of Kallax?
