ᐅ Kallax Tilt Lock Does Not Hold – How to Improve It?
Created on: 3 Jul 2024 08:47
dragan
dragan
3 Jul 2024 08:47
I have a Kallax shelf from IKEA that I have fixed to the wall using the original anti-tip safety bracket for security reasons. Unfortunately, the safety bracket does not hold reliably for me, especially if the shelf is slightly uneven or the floor shifts minimally. The included screws and wall plugs do not seem to have sufficient load capacity, and the shelf can still move or tip slightly despite the safety device.
My question: Do you have practical and proven tips on how to better secure the anti-tip bracket on the Kallax shelf? I am looking for specific solutions, such as alternative fixing materials, special screws, or tricks to ensure a safer attachment.
Thanks in advance for your help!
lisku
3 Jul 2024 09:03
I would recommend using stronger metal anchors instead of the included plugs and screws. It can also help to check the wall for cavities or drywall before drilling and to choose appropriate anchors accordingly.
Lorukeo
3 Jul 2024 09:59
To improve the tip-over safety of a Kallax shelf, choosing the right mounting materials is crucial. The original plugs and screws are designed for standard installations and are not always sufficient, especially for drywall or uneven floors.
I recommend the following approach:
1. Identify the wall type: Load-bearing concrete ceilings or solid walls allow the use of heavy-duty anchors (e.g., expansion anchors, metal sleeve anchors). For drywall, cavity anchors or tip-over brackets are more suitable.
2. Check the floor level under the Kallax shelf: If the floor is uneven, it is advisable to level it using furniture shims or appropriate pads to prevent tipping movements.
3. Replace screws and anchors: High-quality screws (pan head screws with a larger diameter, ≥5mm (0.2 inches)) and suitable heavy-duty anchors significantly increase safety.
4. Additional securing: If possible, also secure the shelf to the floor or connect it to the wall using brackets.
Also consider the load on the shelf. More weight at the top increases the risk of tipping. Slightly redistributing the load can help.
The goal is a firm and stable connection without any play that secures the shelf against tipping.
dragan
3 Jul 2024 10:21
Lorukeo schrieb:
I recommend the following approach: diagnose the wall type [...] replace screws and anchors: high-quality screws (pan head screws with a larger diameter, ≥5mm (0.2 inches)) and suitable heavy-duty anchors significantly improve safety.
That already sounds very helpful, thanks. I actually have a drywall, which is probably the issue.
From your perspective, is it better now to simply get better cavity anchors, or would you recommend securing it sideways to a wooden stud or into a solid wall?
I want to keep things as simple as possible, but without compromising safety.
KLO-KA
3 Jul 2024 11:46
When working with drywall, you must use special hollow wall anchors designed for heavy loads, such as metal toggle bolts or expansion toggle anchors. Standard plastic anchors will not hold.
Maria35
4 Jul 2024 07:33
Additional information on anti-tip measures for Kallax shelves: For drywall, the recommended solutions are specialized cavity anchors, such as metal toggle bolts with a load capacity of at least 50 kg (110 lbs) per fixing point.
If possible, mounting on an existing wooden substrate (e.g., wood studs or a batten behind the wall) can provide significantly more stability. An alternative is to also secure the shelf at the bottom using brackets and screws, so that it is fixed both at the top and the bottom.
Another tip: If the floor is uneven, it can increase the risk of the anti-tip device being pulled out. Therefore, check beforehand whether the shelf might wobble and try to stabilize it with wedge-shaped wooden strips. This reduces the tipping pressure on the wall mounts.
